OCD people say a lot of things that aren't always of any benefit unfortunately. Get the engine warm, pull the drain plug and let the oil drain, 30 minutes works well for me, if you're OCD let it drain longer. Think of how many oil changes a quick lube place like Jiffy Lube does a year. Trust me they aren't letting the oil drain for 30 minutes, they'd go broke. While I'm not a fan of Jiffy Lube, the cars serviced there seem to survive. Honestly I'd find something else to worry about.Yes i know. It's no big deal. But some people OCD said you should not mix this brand/viscosity blah blah... When put new old, surely will mix some old oil.
In terms of pure volumetric measure of what went in versus what went out ( excluding any losses from leakage/consumption/evaporation etc.)When we drain engine oil from the oil pan drain plug, will there still be any more oil inside the engine? Just like draining ATF can only drain about 50% of the fluid?
Who has said you shouldn’t mix certain brands or viscosities?Yes i know. It's no big deal. But some people OCD said you should not mix this brand/viscosity blah blah... When put new old, surely will mix some old oil.
No, More like 5% if you drain pan and filterSo about 10-15% is inside. ok
I always struggled with this. Seems the longer you let the vehicle sit, the oil would have longer to make its way to the pan. But a warm engine would definitely drain faster. Perhaps it may make the filter a little easier to remove to if warm.Their might be. The best way to get it all out is to let it warm up before draining so it flows quicker that’s usually what I do.
I’ve also seen people bump the engine to get it to get as much out as it can though I don’t recommend that. And yeah I usually use the warm engine method when it’s colder since the oil will flow better when it’s warm.I always struggled with this. Seems the longer you let the vehicle sit, the oil would have longer to make its way to the pan. But a warm engine would definitely drain faster. Perhaps it may make the filter a little easier to remove to if warm.
