Troy Built snow blower recommendation
Massachusetts, plymouth county
Troy-Bilt
250cc 28" Dual-Stage Gas Snow Thrower
Item #: 189237 Model: 31AH6WQ4711
Looking for a recommendation for this Troy built snowblower that Lowes sells. What is the HP of a 250cc engine? Who makes this snowblower MTD? Is the B&S engine better than a Tecumseh engine?
Here are the specs on the engine from the Briggs & Stratton website. Probably somewhere between 7-8 HP. Briggs makes a good engine.
Specifications
Engine Rating 11.00 Gross Torque*
Displacement 249cc / 15.22 cubic in.
Fuel Tank Capacity 3.16 qts
Lubrication System Lube Power™
Weight 39 lbs
Valve OHV
Cylinder Kool Bore™
*All power levels are stated ft-lbs per SAE J1940 as rated by Briggs & Stratton.
Originally Posted By: bigsteve
..Looking for a recommendation for this Troy built snowblower that Lowes sells..
It's a decent MTD made machine, just fancier plastic, decals and paint. I personally would MUCH prefer the OHV Briggs over a flat-head Tecumseh engine.
Joel
If I was in the $,1,000.00 bracket and 28" clearance with 8-9 HP. I would get an Ariens 928 from Home Depot.
Good point. Either that, or just get a run of the mill 26" width MTD for $700. That 2" isn't worth $300+ more to me!
Joel
Joel
Agree!
I've got a MTD Craftsman 8hp blower. Works great! My last one had a Tecumseh flat head and this new one has the Briggs OHV and there is NO chance I'd go back. The Briggs is a much better motor and starts up everytime. It has a electric starter that I used once (to make sure it worked).
The Tecumseh would bog down when you got into some deep / wet snow. The Briggs just rips through it not dropping RPM at all.
Also the Briggs seems to use less fuel. I got the Sears on sale about 3 years ago for $619 which incl chains for the tires and 2 year warranty on the Blower / 5 year on the motor.
Take care, Bill
Wow. I have a 22 year old Lawn Boy gear drive snowblower with an 8 HP Tecumseh flat head. Runs about 15-25 hours/season doing an entire cul-de-sac and several driveways. Still runs like a champ, never is underpowered in even heavy snows. It is, I believe, 28" wide. I change the oil at the end of every season using Pennzoil 5w30 conventional and lube it with Mobil 1 grease. I don't think there is a gear drive blower available anymore in any model but correct me if I'm wrong.
Originally Posted By: Boomer
..I have a 22 year old Lawn Boy gear drive snowblower with an 8 HP Tecumseh flat head....
.... I don't think there is a gear drive blower available anymore in any model but correct me if I'm wrong.
Your Lawn Boy is gear drive in that it does not have a rubber friction disk drive system? I've never seen one w/out a friction wheel drive aside from hydrostatic drive Hondas. Even 30yr/old units.
Joel
Originally Posted By: Maritime Storm
...They also tend to start easier & have more torque at a lower RPM. I have last year Troy-Bilt with a OH195SA Tecumseh and never regretted spending the money on it.
Yessir. I've been saying this since I bought my first OHV piece of OPE 10yrs ago. I've avoided flat head OPE engines since.
Joel
I've gone the same way in the past year or so. That having been said I do still have 2 2-cyle engines here, an MTD string-trimmer & my trusty old Mercury 40. Any 2-cyle outboard that always starts on the first pull is weight in gold, this thing sat for 4 years without being used, first time I had my sailboat in the water it started on the first pull.
We have a snow blower with OHV and the thing is a monster. It eats snow and throws it without any effort, even at low revs. I wouldn't go back to a flat head ever... ::)
Yes, mine has a 5 speed gear transmission and NO rubber wheel. The trans is a sealed unit driven by a belt that powers the axles. Great setup but not made anymore by anyone. This is actually a Gilson, as I understand, as Lawn Boy bought them around that time. On the Internet, there seems to be a religiuos following of the Gilson snowblower.
Yes, mine has a 5 speed gear transmission and NO rubber wheel. The trans is a sealed unit driven by a belt that powers the axles...
Cool! I didn't know that existed. They go the cheap route now, that's for sure.
Joel
