Picked up non running Troy Bilt Push mower for $30
Tampa
Picked up this non running troy bilt mower for $30. Unfortunately it's not self propelled. It's probably the lowest model Troy Bilt makes, model 100 I think. It has a 6.5 hp B&S engine. What do you guys think of my cleanup job and how much you think I can get for it (it's running fine now)? Also, the gas cap show 40:1 mix? Is that right or did someone put the wrong gas cap on it?
Originally Posted By: Jeepster_nut
Nice find. What was wrong with it?.
I pulled the fuel bowl and cleaned it all out. The bolt was completely clogged and there was no fuel flow. I cleaned all that real good and noticed the gas coming out of the line was nearly black. I drained the gas tank completely and refilled w/ good clean gas. It was so dark I think they might have actually been running a mix in it and if so it was much higher the 40:1 anyhow.
Every B&S mower I've encountered that "can't start" always has this same exact issue with the fuel bowl bolt.
Haha the 40:1 gas cap is really funny because I can see the cap for the oil in the pictures. That's a 4 stroke engine and it runs on straight gasoline in the gas tank, and oil in the sump. It should fun fine on the oil/gas mixture but it will foul the spark plugs at an increased rate and pollute more, as well as cause some buildup in the cylinder.
It probably cost about $150 new but you did a great job restoring so maybe around $80-90ish?
What was wrong with it, how did you diagnose, and howd you fix? Im really curious to see how you solved this one!
Very nice. Looks new. My FIL gave me a "non-running" power washer with a 6hph B-S motor. I took the bowl off and cleaned all that nonsense out also. I use Sta-Bil now. Non-issue. He's not mechanically inclined.
Change that to fortunately. The self-propel system on most Troy-Bilts is horrible. It's unreliable, thanks in part to cheap plastic components and the stupid "gear" change feature. It can also be very difficult to repair. I can swap out a Toro FWD or RWD transmission almost with my eyes closed...not so much with a Troy-Bilt.
Originally Posted By: hemitom
Im sure you can get $100 for it. Wrong gas cap.
+1. That would sell around here for a hundo all day long.
That cleaned up great. Remember the cheeziest mower at walmart is $129 or so and half the power.
I'd see if there's a universal gas cap that fits, or if you can grind the 40:1 embossment off the one you've got. People don't like the "I did it one piece at a time" approach.
I have a very similar mower from Troy-Bilt as my push mower. Mine does not have the shield around the exhaust and is claimed to have 6.75 ft-lb of torque. I paid about $200 about 2 years ago or so for mine at Lowe's, I think it was. You did a great job cleaning it up and fixing it! You should be able to get $100 or maybe a bit more, depending on how much time is on the engine. How did someone ever wind up running a two-stroke mix through that thing?!
I paid roughly $150 for the 2007 model of this ($220 original price at Lowes) about 2 years ago. You can generally get their lawnmowers for cheap when they release next years model + 10% off coupon. But yes if you want the original price of a mower like this, it's $220 and they generally have it "marked down" to $200.
