trans fluid question. 2008 Jetta Se 2.5
NJ
I have a 2008 Jetta Se 2.5 automatic that I want to change the transmission fluid. I believe it takes G 055 025 A2. I am looking at these fluids. What is the significance of the suffix after the part number G 055 025 A2 XXXX. Also can anyone confirm this is the correct fluid for this application
Brand: Aisin
Part Number: G-055-025-A2-M351
Brand: Fuchs Titan ATF 4000 Part Number: G-055-025-A2-M855
Brand: Febi Part Number: G-055-025-A2-M36
Brand: Genuine Volkswagen Part Number: G-055-025-A2-VAG
The fluids can e found on this page:
http://www.pelicanparts.com/catalog/SuperCat/4365/VAG_4365_TRAUTO_pg1.htm#item0
I am not sure what country you are in. However the Amsoil website lists their multi-vehicle ATF for your vehicle.
Simply put, the Amsoil ATF is one of the best ATFs avaliable. Period.
I would go with Amsoil or VW if it were my car.
BTW - I have Amsoil ATF in the auto transmission of both my vehicles and in the TC of my Jeep.
You have several ATF brands I never heard of, so I am thinking you are outside of the USA?
Febi Brand is part of the Bilstein Group.
Well known quality OEM parts for suspension, transmission, ect...on many European cars, especially VW/Audi, BMW, and Mercedes as well.
If the price is right buy that brand...it is likely the OE fill.
I am in NJ, never updated my location. I have seen Fuchs before but never Febi. Good to know it is a quality product. Those are from Pelican products webpage.
Originally Posted By: drtyler
That is the same as Toyota T-IV and Mobil 3309. The fluid meets the jws 3309 spec for Aisin transmissions. You can buy a case of 12 quarts of Mobil 3309 from Amazon for about $64.
Search around for the T-IV and 3309 spec fluids.
Here is the Mobil site link, says it meets that VW spec / part number.
http://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_ATF_3309.aspx#
Thanks for this info, i am seriously considering this fluid.
