I was reviewing the new/almost new Toyota car lineup (Camry's, Siennas, etc).
They are spec-ed for 0W-16 and come with an electric oil pump.
I watched a youtube video by the Car Care Nut (He is a Toyota Master Technician mechanic who works at a Toyota dealer in Chicago).
He described the Toyota electric oil pump as being programmed to keep the OW-16 oil pressure as low as possible for fuel efficiency.
The example he used was that it would keep the oil pressure at only 10 PSI until the car got up to 3,000 RPMs, and then it would go to 40 PSI
and stay at 40 PSI while the car is > 3,000 RPMs.
The concern I have is that this approach is basically starving the engine of oil lubrication for RPM's < 3,000.
For those of us who like to keep their cars for 10 to 15 years and take them to 200k miles, concern would be the long term impact
of 10 PSI oil pressure for most of the driving. Wear on the piston rings, camshaft, timing chain, etc could accumulate
over the years and turn these cars into severe oil burners.
Even if you decided to use 0W-20 for it's higher HTHS = 2.6 to have less engine wear instead of 0W-16 (HTHS = 2.3),
you would still be faced with that electric oil pump keeping oil pressure very low.
I think about an overloaded Toyota Sienna with 8 heavy passengers + luggage going on a long trip going up mountain roads
in 100 degree weather with the AC with this oil pump limiting PSI to 10 and with 0W-16 with HTHS = 2.3 and asking myself
if I really want to own a car like this. Low oil pressure is not good for engine longevity.
I know everyone will reply saying trust the Toyota engineers, they know more than we do, and you might be right.
But it is your money, you can choose to buy a car without these design changes and not have to worry about it.
