My new Basketcase trail buggy Jeep YXCSJ
Central NY
Thinking the Cherokee's end is near. I just can't keep up with trying to keep a steering box in it (literally ... keeps breaking the front frame rails or ripping out of the unibody). The rear has started to rust to the point that I am very worried about the leaf springs coming up through the floor. Maybe if I can get this one built to the point it can be a good trail rig, I can take the time to work on the stuff on the Cherokee. '
Was looking for full frame jeeps that aren't entirely rusted out. Saw this one on FB for a few weeks keep dropping in price. "Needs a little work" was all that's in the description. That's accurate.
89 Jeep Wrangler
First glance ... it has a wrong side drop axle. When I went to look at it, I was more curious as to how that was accomplished than anything. I was expecting it to have a driver's drop transfer case.
But the frame wasn't terrible - only 2 holes - and the body has enough left to save ... unlike my last YJ.
This is where it gets interesting.
Someone also converted it to a 4.0L. The wiring is hacked to death. I leave the battery unplugged because I'm afraid of it catching on fire. None of the gauges are hooked up. I'm not sure if an early XJ computer would drive these 89 gauges.
Appears that the engine / transmission are from a 91/92 Cherokee because it has an internal slave AX-15. Definitely Cherokee belt routing.
Narrow track Wagoneer Dana 44 axles. I'm going to try to make these work.
The body isn't great. There's about 1/2'' of bondo under the LR Window from it eating a tree. Not rust, just a big dent. I threw on some YJ doors I had and they... kinda fit. I think there's some tweaking going on. I'll need to weld in some floor, maybe fix some torque tubes and the back corners.
The clutch didn't work when I picked it up. I bled it and it's worked for at least 24 hours. I think something's wrong with the slave cylinder. It ran PIG RICH. I let it run for 20 minutes and it had 0 oil pressure on the aftermarket gauge. Checked the oil and it was more gas than oil. They unplugged the coolant temp sensor that was hoked to the computer to run an aftermarket gauge so it thinks it's -40 out and fueling for that. The centering yoke in the rear driveshaft was bad, I just replaced that and put new u joints in.
They also mated it via adapter plate to a CJ-7 Dana 300 case (worth 1/2 of what I paid for the Jeep).
Still have to get the cooling setup figured out. I'm going to ditch the electric fan and swap in a YJ water pump / shroud/fan. I might keave the electric fan hooked to a relay so the XJ computer can run it if it gets warm. Right now it has a bad XJ fan clutch connected to the water pump with no shroud. That does absolutely nothing.
The axles have some highway gears in them. Until I regear , the old q78-16 tires are going to come off and I'll pput on the all terrains that came off my truck. I'm thinking .. if I keep going with this ... 4.88s and lockers in the differentials. Then I'll run a 35 or 33'' tires. It will be a trail buggy so the gears are the most important thing to pay attention to.
I wouldn't mind getting this to the point I can drive it to and from work occasionally. I know the rear driveshaft won't be happy with 4.88 gears on the highway.
Would like to get the gauges working. I'm not sure if the 89 Wrangler gauges can be driven by a 91/92 xj computer.
I love YJ’s, but I would have run from that one. Enjoy!
It's going to be a project for sure. I've helped friends do 258 -> 4.0 conversions in a similar manner.
There's value in the parts in it. If I sold the axles and transfer case (and adapter) out of it, I'd be close to what to what I paid for it. I'm not married to these axles and I could have a stock front axle and ford 8.8 in it for a few hundred dollars. I have a transfer case that would be the right one for this jeep.
Trying to get the stuff figured out and working is a good distraction at the moment. And that's what I need!
A lot of people ran from it ha.
This is typical translation for "needs work."
If it didn't run and had a seized motor, then that's "just needs a fuel pump"
Anyway, I'm undecided on which side of that fine line between genius and insanity you fall here.
It surprisingly needs less work than I thought it would.
I have a stack of parts that would work for this if I decided to switch it back to stock axles / drivetrain.
Friends of mine have started to hoard the older AMC / Willys era Jeep parts. At least I have access to stuff if I need it. One of my friends has like 5 Dana 300s in his garage. Even adding the correct mechanical fan will be pretty easy and cheap since I have friends who have the fan and shroud I need.
Sounds like you know what you got yourself into. No doubt you can make everything work but the rust always wins in the end.
Thanks for rescuing the red-headed stepchild of Wranglers. :( (y)
I know what I'm going to do with it 😁 Within a year I'm sure it'll be beat to death from trail rides and rock crawling. My Cherokee doesn't have a single straight body panel left on it from hitting trees and rocks.
First big project on this is going to be changing out the gears ... I thought it was geared tall. One day I counted the rear rotatsions and came up with high 2s. Seemed weird so I tried the front and came out with 3.55. That seemed more accurate.
Pulled the covers yesterday and found I was right on both. Rear has 2.73, front has 3.55.
I am trying to be cost effective. I think it's going to get thick cut 4.88 gears so I don't have to buy a carrier and i'll get a locker for the front.
Loved my 88 wrangler but those frame rails are worthless. When I sold it I told the guy not to drive it but they didn't listen and broke one rail going down the road. The jeep was only ten years old.
I previously had a 1995 that was in awful shape. Every time I'd take it off road the frame would snap in a different spot.
  • Like
Reactions: Arc
Rear is 2.73 and front is 3.55? That had to be a rolling disaster in 4L, not sure if it could move under its own power in 4H???
It was funny. When I picked it up I was trying to get it into low range to get on the trailer and my buddy was telling me all the way forward (dana 300). I kept saying it's all the way forward but still in high range. It was hopping a bit turning in the seller's yard trying to line up to the trailer - I just figured it had a welded rear. When I got to the wet slippery trailer ramps, the front left tire weirdly spun. I didn't realize then but it was definitely binding up.
It needed a LOT of clutch to get moving in high range. It needs some clutch to get moving in low range, too. 36'' tires and 2.73 are not a good match .
I thought about it more and I really don't know enough about this to drop another $1200 into locking and gearing these axles. For now I'm going to buy a used set of 3.55 gears for the rear half$$$ it together with used bearings and see how the rest of the thing works out.
As much as I'm opposed to them, I have a set of 33'' tires/ wheels from the Cherokee that I'll throw on with some wheel spacers. Then I can get a feel for if the thing will be worth putting any time and money into.
My guess is this had chevy 1 tons under it at some point then someone swapped these in and the chevy axles went to another project.
What an absolute PILE OF TRASH this thing is. I either should have walked away or parted it. This thing belongs in the junkyard.
Had to ...
- patch rear frame section (pretty typical)
- Replaced rubber fuel lines, fuel filter and fuel pump assembly because the lines rusted out
- Replace computer, the wiring is so hacked to death on this thing it isn't funny
- Threw 3.54 gears in the rear so it matched
- Bled the clutch.
Finally got it out on the trail and ... no clutch. There's something wrong with the internal slave cylinder
I have collected all the parts to convert to external slave. So I guess that's next.
I'm not looking forward to wrestling an 85 pound transfer case out.
