The hybrid battery does not replace the alternator.it, and no alternator because the hybrid battery does that job. Still get 37-40 mpg. 2021 Sienna
Incorrect rebuttal.The hybrid battery does not replace the alternator.
No starter? Does it lock the transmission and use the drive motors to turn the engine over?
Toyota wizardry lolNo starter? Does it lock the transmission and use the drive motors to turn the engine over?
It has?Huh?
Yes. I think. The transmission is basically a differential, posing three shafts against each other, like a see-saw. Engine is on one. An independent motor/generator is on another. The third is the output which also has a second motor/generator.No starter? Does it lock the transmission and use the drive motors to turn the engine over?
It does have a transmission, and therefore does use ATF. I think the differential is within the tranny.It has?
did they already get rid of the 2.5?Just wanted to share my experience with this engine. It has been running strong, I am just a little under 200k miles on my 2021. I know some who have hit the 300k mark as well. Oil change every 5k miles and coolant every 60k.
Buy a Toyota blindly with this motor, it is one solid little unit.
Cheers!
I see now. So just changing the transmission fluid takes care of everything unlike other Toyotas, like their trucks. Thanks l for the clarificationIt does have a transmission, and therefore does use ATF. I think the differential is within the tranny.
2.5 is not turbocharged 2.4 is. 2.5 is not going anywhere anytime soondid they already get rid of the 2.5?
new tacomas have the 2.4 turbo
