Amen!! The blue gasket material rips off and sticks to pan or drain bolt.BTW - very easy to double gasket those cars. Not good. The drain plug bolt has a gasket that sometimes find itself stuck to the oil pan. Either reuse the old one or knock it off and use a new one.
? They are a canister filter so unless you put an oring on top of an oring you can’t double gasket it.BTW - very easy to double gasket those cars. Not good. The drain plug bolt has a gasket that sometimes find itself stuck to the oil pan. Either reuse the old one or knock it off and use a new one.
I was thinking of all my other Toyotas. LOL? They are a canister filter so unless you put an oring on top of an oring you can’t double gasket it.
I think he meant double-drain-plug-washer it, not double-gasket the filter cover.? They are a canister filter so unless you put an oring on top of an oring you can’t double gasket it.
Double gasket on the oil drain plug, as stated.? They are a canister filter so unless you put an oring on top of an oring you can’t double gasket it.
Got a friend that has a Sienna with the 2GR-FE, his spring is missing and the tube is somehow stuck to the top. So when he removes the canister, there is nothing inside. He's been driving it like that for years. lolUPDATE!
Watching the CAR CAR NUT and in one of his YouTubes he said if the center post came out to not try and replace it.
He said you must buy a new oil filter cover. I trust his advice. We got a new one for $31.
Why can’t it be reinstalled? Why must you buy a new cover?UPDATE!
I don’t exactly know. Check out his YouTube.Why can’t it be reinstalled? Why must you buy a new cover?
Its not hard for them to come loose. So long as all parts present and installed correctly, I don’t see the issue.
