Toyota oil filter light leak
Just curious if this oil filter leak or seep is significant or it's like many other things in a car which are not "perfect".
For example we discuss and/or analyze engine oil to death ... And the quality of the oil (i.e. approvals, etc.) being up or down some doesn't seem to impact much in general if you follow manufacturer recommended oil/OCIs. Basically it falls under overanalyzing category which I am guilty of as well but also aware of it. :ROFLMAO:
So this oil filter issue (assuming that is valid) fall under that category and/or maybe manufacturers (in this case Toyota) are well aware it but it's not significant or a don't care!
I agree. The high efficiency vs OEM efficiency debate is legit. But paying a premium for a high efficiency filter thats defective and affecting its efficiency is another debate. Better off just running a $6 OEM filter.
So does this oil filter issue (assuming that is valid) fall under that category and/or maybe manufacturers (in this case Toyota) are well aware it but it's not significant or a don't care!
I highly doubt they purposely design oil filters to have a built-in constant internal leak of dirty oil past the media. One of the top design requirements for an oil filter should be "design it for no internal leakage".
The other part of the equation is manufacturing. If they can't manufacture a product to the engineering design and specs, then that's a failure too. That's basically the issue with the ruffled up leaf springs causing a leak gap between the leaf spring and end cap. These ruffled leaf springs haven't been around forever, and they use to be made flat and smooth in the past. It's sloppy manufacturing going on.
What about the voids in filter media. Like some filters from Japan, the holes are extreme.
A bypass valve could be made with a taper where it fits in an end cap that has a almost matching taper. Those areas shouldn’t end up ruffled in manufacturing. It would seal under spring pressure something like a compression fitting but not that tight. Very simple, wouldn't cost more to make.
You mean a leaf spring? ... which isn't really the bypass valve.
I'm pretty much going with filters these days with a coil spring instead of a leaf spring, and also no louvers. Better design aspects overall.
A tapered cork is a very old idea. They use a cork to do the bubble point probably.
WCW has a new video on a Honda Japan filter, interesting. Seems to have caught a lot of debris in the can over 6k, but the media is porous.
When Honda went to Fram for filters, they specified their own media design, less efficient. They could have used the efficient EG media instead. Remains mystery.
