Originally Posted By: Garak
Originally Posted By: Gokhan
Originally Posted By: Shannow
I've never come across a study on the colorimetry of used oil filters, hope that you can link me to some.
I guess you insist on colorimetry before you vacuum your carpet as well.
The real point is that colour tells us so little. As mentioned, OCI, oil formulation, original filter colour, lighting, air filtration efficiency, and so forth can all affect what you see on the same engine, much less trying to compare two different vehicles.
I wasn't even talking about color and then Shannow brought up colorimetry. That was the reason for the sarcasm. No, I was referring to the amount of dirt collected by the two filters. Of course, when there is more dirt, you not only see more visible dirt on the media but the media also appears darker. Somehow he jumped onto colorimetry and oil oxidation from there. From what I've seen, cartridge and cartridge-core-canister Thailand Denso oil filters, not Thailand Denso oil filters in general, consistently don't collect as much dirt as other oil filters. This is in no ways scientific but consistent with the scientific tests conducted by the independent laboratory for Amsoil. Again, this is a simple observation on many images posted on the Internet and I don't see why it gets cherry-picked, while the critics find no counter examples. Besides, it's not necessarily a bad thing. Some people find low efficiency useful as it allows longer OCIs and very high-efficiency oil filters may clog very early during the OCI.
I also don't understand brand loyalty when it comes to oil filters. Fram, Purolator, Champion Laboratories, etc. oil filters vary wildly in quality, anything from unacceptable to as good as it gets. Denso, having its oil filters manufactured by third-party companies in many places around the world, is no exception. Some Denso oil filters are excellent and others are so - so. However, I agree that none are unacceptable and they will all be adequate in the intended applications. To argue that you can never do better filtration than even the cheapest Denso oil filter as some have been on this thread is silly. We are talking about low-grade-paper Denso oil filters that sell for $3.84 versus Fram Ultra, Mobil 1 Extended Performance, etc. for God's sake and the cost to the Toyota dealer is probably under $3.
https://www.toyotapartsdeal.com/oem/toyota~filter~s~a~oil~90915-yzzf2.html
https://www.toyotapartsdeal.com/oem/toyota~replaceable~element~04152-yzza6.html
It turns out TBDN Tennessee Company makes the USA-made oil filters for Denso. Their other customers include Toyota, GM, FCA, Honda, Mitsubishi, Subaru, Benz, Ford, and Hino.
My answer to the OP's question: Yes, no need to say, of course, it's OK to use the Toyota/Denso OEM oil filter, even the made-in-Thailand version I'm skeptical about. However, since you seem to be interested in experimenting for better alternatives, of course, there are better alternatives as well. In your case, experimentation is actually simple and fun. You have a cartridge oil filter and you can actually see how the filter did when you change the oil. Simply experiment with different oil filters, anything from the lowly Fram Extraguard to the mighty Amsoil and Royal Purple, along with the Denso, and see if the cartridges hold up physically and how much dirt they actually seem to have sucked in the media. (If you want to get scientific, you can even compare the weights of the new wet cartridge to the used wet cartridge but that requires a scale.) You can then be the judge and decide which oil filter is the best yourself and even create a thread with the pictures from each experiment.
