I have an 04 toyota highlander, 93000 miles, had brakes done 8000 miles ago using oem parts- pads rotors.. last few weeks I get a drivers side front brake area noise. I can reproduce it 100% by driving at 35 MPH and driving over the rectangular lane divider dots (botts?) that are on the road. Thats a quick hard impact. no noise when over smooth dips in the road. makes a clack/rattle noise when the tire hits the dot. lug nuts are tight - steering seems tight. never wrecked, It does it when accelerating and when coasting. It does NOT do it when you put your foot slightly on the brake as you hit the dot- which makes me think its brake related. I jacked up the car under the door and the tire seems tight (ball joints ok?) when you push and pull on top or bottom of the tire. sway bar bushing and sway bar links "look" ok.
Caliper pins worn? how to check? something wrong with brake hardware?
Ideas? the 2 14 mm caliper pin bolts are tight and the 2 17 mm caliper bracket bolts are tight.
