Originally Posted By: Gokhan
Originally Posted By: ZeeOSix
^^^ You're comparing electronic filters to physical filters ...
no comparison. Physical filters like oil and air filters will catch the whole range of particle sizes as the graphs I posted show.
Electronic filters
are physical filters, made from physical capacitors, inductors, etc. That graph is very similar to the graph you posted.
Particles range in size from electrons, protons, atoms to planets and galaxies.
Just like the cutoff is defined for -3 dB [= 10 * log(50%)] for electronic filters, oil-filter nominal micron rating is defined by 50%:
The two most popular reported media ratings are a nominal micron rating (50%)
and an absolute micron rating (98.7%). A nominal rating usually means the filter's
media can capture a given percentage of particles of a stated size. For example,
a filter might be said to have a nominal rating of 50% for particles 10 micrometers
in size or larger. An absolute micron rating can be determined by single-pass or
multi-pass testing and is usually obtained by passing a test fluid containing
particles of a known size through a small, flat sheet of filter media. Any particles
that pass through the media are captured and measured. An absolute rating is
also expressed in the form of a percentage of the size of particles captured.
www.hastingsfilter.com/Literature/TSB/89-5R3.pdf
http://www.baldwinfilter.com/ProductHighlights122010.html
Your "cherry picks" have nothing to do with trying to associate electronic filters - which attract particles by electrical forces - to filters using actual MEDIA ... that's what I meant by physical filters. Not "attractive force" driven filters like an electronic filter which acts in a different manner than media type filters. You're links are just describing how filter efficiency has been defined with terms like "absolute micron rating" and "nominal micron rating".
There is no distinct "cut-off" with media type filters. Their efficiency curve will be like I posted ... not like the graph you posted of electronic filters.
Here's a couple more media type filter examples ... there is not "cut-off" to speak of.
Air Filter
Oil Filter
