Originally Posted By: Gokhan
Originally Posted By: ZeeOSix
Note that the x-axis is a logarithmic scale, so it has no bearing on if the curve shows a cut-off knee or not. It won't show a cut-off if there is no cut-off. Goes for a non-logarithmic scale too.
The only problem is that the logarithmic scales never end in zero, which is the equivalent of minus infinity in a linear scale.
Apart from that mistake in that plot, the scale only covers a factor of about ten in particle size; so, it really doesn't matter if you plot it linearly or logarithmically.
To me all three curves there have sharp knees. This is really not different than a first-order electronic filter. The formula is 1/(1+x^2) for the first-order electronic filter. You can plot it here (just copy and paste the formula in) and see that it's really not that different in appearance.
https://www.desmos.com/calculator
We are going in circles here and this is really a moot discussion. I think we should agree to end this discussion.
You must be seeing things. Those curves are not even close to the one you posted earlier and claimed oil filters follow the same kind of "cut-off" (shown below).
Back peddling ...
