It’s a wonder it doesn’t break with every cold start.Seams to be pretty light oil for a diesel
That would be a no go for me
Switched out to Mobil 1 Dexos 2 5W-30 two changes ago. First two were Dexos D. No concerns about going to a 5W-30 since GM has an approved oil at that vis that they aren’t marketing yet. Have never done any UOA on any previous vehicle but might at 20k just to see. That’s a ways off, though. We’ll see.Are you still running 0-20? There was a tab for broken welds on some cam covers but some people seem to be losing oil and supposedly don’t fall under the part number range for the issue
Where have you seen they have a 5w30 dexos D? Just curious? I just wish we knew the requirements of dexos D.Switched out to Mobil 1 Dexos 2 5W-30 two changes ago. First two were Dexos D. No concerns about going to a 5W-30 since GM has an approved oil at that vis that they aren’t marketing yet. Have never done any UOA on any previous vehicle but might at 20k just to see. That’s a ways off, though. We’ll see.
No that’s not what he’s saying. dexosD cannot be a 30-grade per the low HT/HS and the licensing requirements.Where have you seen they have a 5w30 dexos D? Just curious? I just wish we knew the requirements of dexos D.
By definition DexosD is going to be a 20 grade, it's GM's rebrand of ACEA C5 which stipulates the HTHS viscosity be between 2.6-2.9 which means it's Xw20Where have you seen they have a 5w30 dexos D? Just curious? I just wish we knew the requirements of dexos D.
Yeah I just read his statement that said GM has an approved oil at this viscosity they aren’t marketing yet. As him referring to dexos DNo that’s not what he’s saying. dexosD cannot be a 30-grade per the low HT/HS and the licensing requirements.
Yep. I assumed it was their money grab at c5 but they haven’t released the official requirements to meet dexos D.By definition DexosD is going to be a 20 grade, it's GM's rebrand of ACEA C5 which stipulates the HTHS viscosity be between 2.6-2.9 which means it's Xw20
So who’s going to pay for it and make it public for all of us
Someone who is willing to put themselves at risk of legal action.So who’s going to pay for it and make it public for all of us
I did find the actual specification online somewhere, apparently they did addend the spec to add a 5W-30 with an HTHS between 2.9-3.5, but there are currently on DexosD licensed 5W30 oils and no vehicle calls for that viscosity grade and DexosD, and essentially Amsoils DexosD is a little contradictory, it says it's also Dexos2, Dexos2 should have an HTHS more than 3.5 while DexosD should have an HTHS less than 3.5, which makes an oil that claims both contradictory.
It's possible to interpret that revision description in two possible ways, and you assumed the wrong oneRevised HTHS for 5W-30 engine oil from 2.9 to 3.5
As soon as the reflash 22 trucks show up with the higher towing ratings I’ll be sure to check out of the new diesel supplements and see if they mention the 5w30 specGMW18006, 3rd Ed., Nov, 2020
Description / Abstract:
GMW18006, 3rd Edition, November 2020 - dexos D Diesel Engine Oil
Note: Nothing in this standard supercedes applicable laws and regulations.
Note: In the event of conflict between the English and domestic language, the English language shall take precedence.
Purpose/Material Description.
This specification details the materials and performance requirements of dexos® D 0W-20 and 5W-30 diesel engine oil.
https://global.ihs.com/doc_detail.cfm?item_s_key=00757150
Let's hope and shoot for 5W-30 oils with an HTHS of 3.5 . It's right on the money. And for those out there that said GM would eventually relent and issue a spec for a higher viscosity oil (and subsequently higher HTHS), you were right.
I can’t imagine that they are specifying a range. Do you know of any other license or approval that gives a range? Of course it may be in this case because of whatever reason, but I’ve only seen ones that specify a minimum.Hint:
Ah, the joys of the English language and its prepositions....
- Revised HTHS for 5W-30 engine oil from 2.9 to 3.5 (it used to be 2.9, now it was revised to 3.5)
- Revised HTHS for 5W-30 engine oil from 2.9 to 3.5 (it has been revised, and now it's a range from 2.9 to 3.5)
The report contains info on:Someone who is willing to put themselves at risk of legal action.
At the bottom of every page (among other things): the purchaser's name, license serial number, date/time of access, and the text "Reproduction, distribution or publication of these standards is expressly prohib" [sic].
Sorry to be the bearer of bad news. GM can be very protective of their specifications.
But then again if this license gives two different grades then you don’t have much choice. I can’t see how you’d straddle both here.
A little late to the party but personally I like the Castrol 0w30. Historically it's been a solid oil but admittedly not quite the same as before. Made in Belgium I believe, if that means anything to you.I have a GM 1500 truck with light duty 3.0L diesel. No problems with using the recommended 0w-20 oil in winter when not towing, but in summer (where it gets up to 100F here) while towing an 8K lbs trailer, I'm thinking I need something more heavy duty. I do OCI every 5K miles regardless of anything. What would you say is best from the following list, and do you see any problem using any of these besides the recommended oil:
Mobil 1 ESP 0w-30
Penzoil Ultra Platinum Euro LX 0w-30
Castrol Edge Euro Formula 0w-30
Valvoline European 0w-30
Mobil 1 is the most expensive by far, so would prefer to use one of the other three if they are comparable.
