Do I Need To Make Any Changes To My Lubricants Selection?
Toronto, Canada
This is for a small fleet of Freightliner M2 Business Class box trucks used by a moving company primarily for in-city pick up and delivery. I have been using the same oil and grease for the last fifteen years and have not had any issues. used oil analysis have been good. Have not looked into alternatives and was wondering if there have been changes in the lubricants market over the last fifteen years that merits me looking at alternatives. We have an account with the local Mobil Distributor (Brenntag) and get good pricing.
Engine Oil - Mobil Delvac One ESP 0W40
https://www.mobil.ca/en-ca/lubrican...-lubricants/products/mobil-delvac-1-esp-0w-40
Chassis Grease - Mobil Unirex EP2
https://www.mobil.ca/en-ca/lubricants/for-business/heavy-duty-lubricants/products/mobil-unirex-ep-2
I don't do extended oil changes and stick to manufacturer recommendations. OCI varies from 9 months to a year, during which the trucks run 16K kms to 24K kms. The chassis gets greased twice a year.
used oil analysis are what they are!
There are other oil's out there that are better, whether my thoughts on better oil's will make a difference, I just do not know. The oil you are using is pretty good, so, no problems, just stick with it.
Just curious, an example of a oil that is better? Delo, Rotella?
Those choices are top end products. Are you having trouble with component. engine life?
I’d use a narrow range oil for the better shear rate. At my work we use semi synthetic 10w30 for the equivalent of 40k miles and have no oiling issues. Also very oil taxing regens. (More or less wot for 45min)
For the grease we just use a petroleum based EP2 grease, but the machines have automatic central greasing so the operators don’t have to do it everyday.
I see you are curios, but you have had no problems with what you are using. I think that these oils would be better:
1) Amsoil
2) HPL
I will say this about HPL, you might want to give them a call and talk with them. You might find that you can extend your OCI's with this oil.
That 0w-40 product is a very good product for colder climates. If the truck stays local & you plug it in during cold months then you could try Mobil Delvac 5w-40 or (Mobil Delvac Extreme 15w40 (Only if the truck engine kept warm). Otherwise just stick to what you're using as that is Mobil's top shelf full synthetic HDEO product.
Mobil specifies V100 to be 14.6 mm2/s. The last UOA for the truck, done by the local Caterpillar dealer, with 21K kms on the oil, measured V100 at 13.1.
Does that indicate a lot of shearing? I don't know.
Some viscosity loss- yes, but out of grade- no. You may want to try Mobil 1 15w40 and see if the viscosity drops as well. The 15w40 uses less viscosity index improver than the 0w40, hence the lower difference in spread. Lower vii is supposed to be more shear stable. I would not change my brand but maybe try the 15w in a few trucks and see what it is.
No, and what you are doing is perfect. Delvac, formerly Esso XD-3 was my go to oil for years, but to save a few bucks I switched to Duron about 10 years ago.
I’d stick with the 0W40 grade for year round use without worrying about seasonal changes.
No electricity available where the trucks are parked and the trucks have always started, even in bitter cold. Hence the need for the 0W.
I was a bit surprised when Strumpan posted about using 10W30 in Sweden, which is at least as cold, or colder, than Toronto. It just occurred to me that his trucks are probably plugged in overnight.
Not trucks but wheel loaders and such. A majority has diesel heaters for the cab and engine but not all. We also use 15w40 is some equipment.
