The WSS-M2C961-A1 spec you referenced is incorrect. You need Ford Specification
WSS-
M2C171-
F1. Use a 40 grade. Here's a small list.
15 quarts
You'll want to use an oil that's "Approved" for or "Meets" Ford Specification
WSS-
M2C171-
F1
You can find that on :
- Mobil Delvac Extreme 15w-40
- Rotella T4 & T6 15w-40
- Chevron Delo XPS 15w-40
- Super Tech 15w-40 "Conventional" & they have a newer "Full Synthetic" version I did a VOA on HERE
- Castrol GTX 15w-40
- Traveller at TRACTOR Supply 15w-40
- Oreilly's Auto 15w-40
- Fram at Advance Auto 15w-40
- Sinopec Synthetic 15w-40 <---I've run it with success.
I don't have any problems using an oil that says it "Meets" that...
15 quarts
WSS-
M2C171-
F1
15 quarts
WSS-
M2C171-
F1
Why would a slow turning v8 diesel that will never see more than 3k rpm care about a F1 certified oil? That’s like caring about if the oil is JASO FC.
Also VDS 4.5 isn’t hard to meet. Most dino oils meet it.
Because some CK-4s have reduced phosphorus and corresponding ZDDP than the F-1 specifies as a minimum.
In Canada, Duron is an option to Rotella and so is Turbo Diesel Truck Delvac 5w40.
Case in point, last month I bought a five gallon pail of Delvac 1300 Super 15w40 for $78 Canadian$, which works out to $56 USD.
Add ten bucks for a filter and I did my daughter’s L5P for $40.
Someone posted that if a person can’t afford $175- $200 USD for an oil change, they should buy a beater instead. In this case, a 3500 Highcountry is a beater.
In addition, all API, ACEA and manufacturers approvals include a foam sequence test.
So no, they don’t foam up like beer in your engine.
Several HDEOs are also suitable for use in motorcycle engines which run significantly higher rpm than Diesel engines in a pickup truck.
Each to their own, but I would rather do four oil changes with plain Jane oil instead of one oil change with an exotic.
I won’t be oil shamed into spending more when my average car & truck payments have averaged over $1,200 a month for the last 20 years. And I didn’t buy them to test engine oils and fluids.
