Hope this helps
2008 VOLKSWAGEN RABBIT 2.5L 5-cyl Engine Code CBUA
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......SEO[1]
AMSOIL European Car Formula 100% Synthetic 5W-40 Motor Oil (AFLQT)
All TEMPS......5W-40, 5w30, 0W-40
Fluids
Brake Fluid......HBH
AMSOIL Brake Fluid DOT-4 (BF4SN)
Clutch Fluid......HBH
[1] Only use engine oil which is formulated to meet Volkswagen
Oil Standard 502 00.
FILTERS:
Oil Filter MANN Oil Filter (HU7196x)
Air Filter Absolute Efficiency Air Filter (EAA240)
Air Filter MANN Air Filter (C43102)
Cabin Air Filter
Cabin Air Filter [1]
Fuel Filter MANN Fuel Filter (WK692)
[1] Charcoal Impregnated
NGK PLUGS AND WIRESETS:
No Recommendations
WIPER BLADES:
Blade Class Driver Passenger
NeoForm T162415 [1] T161915 [1]
[1] OE Design
CHASSIS LUBRICATION:
0 Fittings, 0 Plugs
CAPACITIES:
Engine, with filter..........6.4 quarts [1]
Cooling System, Initial Fill..........10.1 quarts
AMSOIL Antifreeze and Engine Coolant
[1] To prevent overfilling during oil changes, add 0.5 liter
(0.5 quart) less than capacity shown, start engine, let run
until engine operating temperature is approx. 60 °C (140 °F)
, switch engine off, wait 3 minutes, check dipstick,
fill to full mark as indicated on dipstick (may be more or
less than 0.5 liter (0.5 quart) depending on model).
TORQUES:
Oil Drain Plug.....22 ft/lbs [1]
Manual Transmission 0A4
Fill Plug 30 ft/lbs
Drain Plug NA ft/lbs
[1] Replace drain plug with new drain plug after each removal.
2008 VOLKSWAGEN RABBIT 2.5L 5-cyl Engine Code CBTA
Engine Oil
Grade 1......SEO[1]
Fluids
FILTERS:
Cabin Air Filter
No Recommendations
WIPER BLADES:
[1] OE Design
0 Fittings, 0 Plugs
CAPACITIES:
TORQUES:
Fill Plug 30 ft/lbs
