Toro straight shaft trimmer head at Lowe’s
Elkins45
Site Donor 2026
Northern KY
I have the toro 60v but its not the power head system.. just regular trimmer.. works great.
This part should come standard when you bought a compatible top-motor trimmer. There are other attachments sold separately such as tillers and chain saws. There is a rotating shaft from the top to the bottom which detaches in the middle to change attachments.
The smaller electric trimmers have the motor at the bottom and only work as trimmers. It has a straight shaft but bottom motor. They are slightly more tiring to use than top motor because the weight distribution is not as good.
I don’t have the Toro power head but I have a gas trimmer with interchangeable attachments. Everything I’ve read says I should be able to use these with Ryobi, Husqvarna, etc. gas power heads. It looks like the normal Trimmer+ attachment in the photo.
interesting I have a nothing special 28cc craftsman gas trimmer that could certainly use a fresh trimmer head.. but I use it about 4x a year now.. and 2x with the edger head.
I’ll know for sure if they fit when they’re delivered on Friday.
I was shopping for a new straight shaft trimmer attachment and most were $100 or more. The price on these was so good I orederd two just in case they might actually work.
I just received a new trimmer head today in the mail. I have a craftsman 4 cycle trimmer, and the head was pretty beat up and not doing it's thing. Beside being 3 times as heavy as my old 2 stroke trimmer, it runs pretty good. I'll go put it on and give it a whirl, when the temperature is a bit cooler.,,
Yes it should fit anything that is trimmers+ compatible. I used to have a Toro power head and used many trimmers+ attachments from different brands on it.
I realized I hadn't ever followed up on this. It definitely fits my Husqvarna Trimmer+ gas powerhead and works great.
