L ledslinger Joined Jun 21, 2009 Messages 1,224 Location Missouri Apr 19, 2015 #1 Its actually a differential with mostly plastic gears and housing. The pinion is steel. I was thinking of using Lubriplate 105 or 90W gear lube. The original lube smelled sulphery like gear lube. Is normal gear lube compatible with plastics?
L Lubener Joined Jan 22, 2011 Messages 9,572 Apr 20, 2015 #2 The older Toro gearboxes I had to deal with had gear oil in them. The gears were steel.
