I would change it every 20 hours of operation and first time after winter. Time how long it takes to use a tank of fuel and factor that into 20 hours.Hi,
Just serviced a friends lawnmower. Replaced the standard stuff, air filter, spark plug, sharpened blade etc.
Interesting, these particularly Series 80000 Briggs & Stratton engine don't require a oil change for the life of the engine!! Just top up as needed.
Well this is the lawn mowers 3rd season. On inspecting the oil, it was extremely dark. So I edged on the side of caution and changed the oil. It had done around 75 hours and the original factory oil.
I used Supertech 5w30 fully synthetic. Ambient temperatures in the area doesn't go above 90 Fahrenheit. Briggs and Stratton have this particular oil weight as acceptable on their website. Just worried when I saw the state of the original oil. I just had to change it for her!!! Also it had been 3 years on the Champion Spark Plug and original air filter. Both were in desperate need of replacing.
So my question is would you run the same oil for the lifetime of the engine and top up as necessary? Or would you still change the oil at the end of the season?
Thanks.
My Poulan push mower came with a Kohler XT675 3 years ago. Manual said change oil every 20 hours. On the first oil change I discovered there was no drain plug. Last year they proclaimed the new ones do not need to have the oil changed. A tank of fuel lasts 1hr 15 minutes. I change the oil every 16 tank fulls.
This engine is great. Always starts. Unlike all the B&S motors I have had before it never refuses to start if you stop it in the Texas summer heat.
Unless they started building these engines with some super duper metals, this is just another exercise in planned obsolescence.
