What say you?
Would you use Top-Tier fuel with nothing in it or use any fuel that was the cheapest even if not name-brand but add a PEA fuel system cleaner to each fill-up?
Or would you use PEA fuel system cleaner in a Top-Tier fuel to ensure your engine is super clean?
I was thinking of ditching Shell here which always seems to be a few cents more per litre than the other guys and just going with the cheapest fuel with some PEA based fuel system cleaner added to each tank to make up for the additives not in the fuel like Top-Tier has...
