I'll be eagerly anticipating your photos.quote:
Originally posted by Red Dog:
Astrovic but ill holler back after I cut one open
![smile.gif](https://bobistheoilguy.com/forums/images/icons/smile.gif)
Still, I understand what you're saying. I like Purolators, too.
Yes, I would even take an OEM filter made by Honeywell built to OEM quality standards than one that is reverse engineered, built as cheaply as possible. [/QB][/QUOTE]quote:
Originally posted by Tones:
Inlet and outlet holes are not an issue. If you look at a Permacool sandwich adapter ..it has only ONE hole and typically handles the entire oil flow of the average engine when installed to mount a bypass filter. Small holes ..big holes ..doesn't really matter much for 99.9% of the engines out there. The oil just accellerates through the opening. It does create a pressure elevation upstream ..but typically only about 2PSI (for the Permacool relief port).quote:
I have never understood how a clicker type bypass valve could possibly work either. It is good they seem to be moving away from them.quote:
Originally posted by boxcartommie22:
i looked at super tech and it bothers me why anyone would want to use such a terrible looking filter small inlet holes and outlets...i will stick too motorcraft, wix, ford racing filters
Where do you get that? From my measurements, the ST has more than twice the filter area of a Fram.quote:
Originally posted by Coop0129:
Might as well buy a Fram.....quote:
Originally posted by Ray H:
SuperTech
SuperTech
SuperTech
Wix..Napa Gold...(same thing)
Denso
Purolater PureOne...but has flow restriction issues in some applications...
Over $6...Mobil 1....K&N
These Toyota OEM filters are Denso filters. Very good filters.quote:
Originally posted by Hirev:
Now days I just use OEM Toyota oil filters since both my daily drivers are Toyota. I can buy them for $3.95 and quality seems to be good.
Buying a good filter does not always mean having more filter media. The media can be constructed of different materials. Also, bypass valve, casing, gaskets, etc.... have a lot to do with how dependable a filter is. Having a good bypass valve is important if you have extended OCI's. Supertech, I would never use for more than 3k, more than that you can just hold your breath. Just my $0.02, and I understand people will have there opinions as well.quote:
SuperTech
SuperTech
SuperTech
Denso
Sorry, I don't agree. Regardless of how often a bypass is needed, I expect it to open at the correct time/pressure, and close and seal when not needed. I do not have a good feeling about any of these aspects with this style bypass valve. The only reason the clicker type bypass was used is because it is the cheapest thing to make, which is exactly my point and brings this back on topic. To each his own, but I would rather spend an extra $2-$4 for peace of mind.quote:
Originally posted by Gary Allan:
A bypass is rarely in use ..ever. If you can still find a clicker ST filter, cut it open and see how the spring interacts with the endcap and how easily the bottom endcap flexes....
Here's the difference in WIX (note the gaps/overlaps in applicationsquote:
Originally posted by axjohn:
Ewetho wrote:
"FL-2005 is the same as FL-400 with an anti-drainback valve, used on Zetec Ford engines to prevent valvetrain noise at start-up."
Where did you get this info? I've been wondering for a long time if the 2005 was the same as the 400 (e.g., 'same' being 3/4-16 thread, approx 8-11 or so bypass pressure). If so, I'm stocking up at Wallyworld when they run out of the FL-400s
Nope. Not in my opinion.quote:
Do you think there is any practical difference between 8-11 PSI versus 16, in the real world?
I could not agree more with your filter choices. I also agree that you could theoretically stick any filter that would work on your car and never have any problems (IE..the supertech) but, you are taking more of a risk.quote:
Originally posted by Bryanccfshr:
I used supertechs exclusively in a Mitsubishi Outlander and never had any issues with the filters. Back on topic.
1. I can get Wix for less than $6 at O'reilys down the street so it's number 1 and what I have begun using in my two new Toyota's. Good looking filter, sturdy, nice internal layout and good materials. The black paint is probably the best color for the engine bay as well.
2. I like the Denso Toyotas as well and noticed my original made in Japan models had silicon ADBV and from what I could see very nice media, interestingly they had O-rings intead of flat gaskets. It is only number two because it requires going to the dealer or mail order so it is inconvenient.
3. I like Purolater Pure ones, not only for the inside parts but that blue paint job is exquisite. Unfortunately Pepe boyz is farther away than the nearest dealer so it falls to #3
I think I will stick to Wix for a while.
