2010 Rav4. ST9972 FILTER
Smaller ones have better rigidity and are less likely to become serial wavers
So my neighbor asked me to do a quick oil change today on his daughter's car. Ran to wallyworld real quick for a filter and the only one they had in stock was the supertech. I often don't use supertech but did notice these are wire backed. Filter seems pretty nice quality for the under $3 bucks at walmart. Has this filter always been like this or is this new? For the money it's not bad at all
Wow! Good find.
I looked at the ST9972 model in my local store today. They stocked about seven, and all of them had pleats that were uneven or otherwise poorly spaced. I will keep checking when I am in the store but so far i am not overly impressed.
Did they look the same as the one I posted or were they different? I didn't have a chance the other day to run to the other Walmart and check them out
It looked like that but the pleats were not nearly as even. They were glued nicely into the end caps so they would likely be fine, but they were just uneven.
I just bought two ST 9972 at $3 a piece. Whoever is the manufacturer, it looks like a the old-school unicorn tear Fram Ultra synthetic filter. Of course the media quite is different but solid end caps and wire backing.
Does anyone have a supertech particle count report?
Going to try the ST9972 my next oil changes in my 2017 RAV4 and 2018 Highlander. I didn’t know these existed until I saw them in Walmart the other day.
They started appearing in Walmart stores around the beginning of the year if I remember correctly. They are not new. I haven't used any because I have a stash of OEM and protec filters, but when I run out of those I'm switching to these Supertechs.
