So today I did some detailing work on the Accord. Since I purchased it over a month ago, it has had some hazy spots in the paint. It is the Taffeta White single stage paint, so its more prone to oxidation than a base / clear coat system. Products used were a Harbor Freight DA polisher, HF orange pad (for swirl/scratch removal), Meguiars Ultimate Polish, Optimum Opti-Seal, and some Blue Coral car wash for getting it cleaned up before and after polishing. I started with a wash and dry, then began the polishing process. I worked on one panel at a time except for the hood and roof which I divided into 4, and 2 sections respectively. This was my first time using a DA (or any) polisher, and it was very simple to use. After polishing each panel I washed the car again because some of the foam had been eaten off the pad and was all over the car. Once the second wash was complete I dried the car then topped with Optimum Opti-Seal.
** In additon to this detail, I removed the factory pin stripes, I figured now was as good a time as ever since I was going to be polishing the paint and they would just be in the way (and since I didn't care for them to begin with), I prefer the cleaner look without them. All in all this detail went well from start to finish, and the paint is MUCH improved. Its not perfect but its now at a level that I am satisfied with.
