To double drain and fill or not?
Recently bought a ‘23 Chevrolet Blazer w/ 9T60. It’s coming up on 30k miles, where I intend on servicing the transmissions.
No external filter, just a small internal one. So, I will be doing just a drain and fill. With being low miles, should I do a single drain and fill or a double. I will be switching to a full synthetic Dexron VI rather than OEM Blend. For the next services, should I continue with only single drain and fills after getting all the break in fluid out?
With just 30k one spill is fine. I'd only do two or more on something that has dark fluid. I'd do a single spill and fill afterwards. I've never done two on any vehicle I bought and maintained since new just used ones with dark red fluid.
I was thinking the same thing, thanks!
A single drain and fill will be fine, particularly if you plan on staying on a 30k service interval for the tranny. You are doing better than most on servicing a transmission, with 60k service being quite common, and even without regular services, GM transmissions tend to last a long time on the original factory fill.
It’s good to see that you’re doing the drain & fill at ~30K miles; way to go! (y)
To me, 30K is not early as some techs/dealers may think, it’s on time IMO.
And every ~30K from here on. I typically want to change the filter(s) on the 3rd spill & fill.
Keep up the good work.
