CleanSump
Site Donor 2026
Do you have a gasser or Bluetec?If you want tungsten, go with Rislone Nano Prime. Works great in my Benz E350.
Good old “nano” to wow the county fair crowd.If you want tungsten, go with Rislone Nano Prime. Works great in my Benz E350.
Yes. Try it and you'll see your oil consumption go down.Good old “nano” to wow the county fair crowd.
Gas. It will work with diesel, too.Do you have a gasser or Bluetec?
He’s not going to use it … but heard a rumor that he did click on the link …Yes. Try it and you'll see your oil consumption go down.
Nah I see through such nonsense. New user relentlessly advocating some additive? Yeah.He’s not going to use it … but heard a rumor that he did click on the link …
So how much torque and hp I am getting with this Nano thing?If you want tungsten, go with Rislone Nano Prime. Works great in my Benz E350.
Forget the 0w-xx, they're just blanket oils that cover every possible temp. scenario. Go for a targeted 5w30, like Red Line High Performance.
And pitching redline constantly as well.Nah I see through such nonsense. New user relentlessly advocating some additive? Yeah.
bigger fan of this https://echa.europa.eu/sk/registration-dossier/-/registered-dossier/7035/4/1It's commonly in the form of titanium isopropoxide.
Isn’t the LL c3 approved? It’s only $24I emailed BP. Yeah, I know. Crazy of me.
Here's the response:
Thank you for contacting Castrol North America.
The following Castrol EDGE fluids are engineered with Fluid TITANIUM Technology to transform under pressure, increasing its film strength to prevent oil breakdown and reducing friction to unlock maximum engine performance:
The "Fluid TITANIUM Technology" call out may now appear on the back label on these products.
- Castrol EDGE 5w30 C3
- Castrol EDGE 5w30 LL
- Castrol EDGE 5w30 U.S.
Castrol always recommends following the guidelines of the engine manufacturer for the recommended oil (i.e. SAE grade, API rating and manufacturer specifications) specific to your application. This information can always be found in the owner’s manual or by contacting the manufacturer directly. Before using any lubricant, ensure that the lubricant product specifications meet or exceed the lubricant specifications required by the Original Equipment Manufacturer (OEM) for that specific use.
Thank you again for contacting Castrol, we value your patronage!
Castrol Consumer Relations
Doesn't matter to me anymore because you guys all drove the Walmart price of C3 up so I'd have to buy Pennzoil. I know it was a plot.
Yes, but this is BITOG so I had to complain!Isn’t the LL c3 approved? It’s only $24
I'm sure you've seen elemental sodium in water - that one valence electron makes all the difference!Nobody is putting elemental titanium in the oil, it is a compound. Just as nobody eats elemental sodium in sodium chloride.
Most people I'd bet associate titanium with metal. And why on earth would you put metal in oil... so people either thought they were crazy, or they just had very bad marketing folks.
TiO2 was also recently classified as a carcinogen in EU.
Coating Rifle BulletsI wonder what those same people would associate molybdenum with?
