Sure if you’re starting unaided below about -30 or so, above that there’s no guarantee the one with a 0W rating is thinner than the 5W rated oil.Increasing both numbers seem like a jump to me, instead of stepping up in only one. That makes sense?
At that temperature I’d have a supplemental heat source such as a block heater. You’re pushing the pumpability limit of a 0W rated oil.With mornings of -40 to -45C not including windchill which would you choose?
As far as I know it isn’t an option. Same with our Tiguan, but we have an oil pan heater, battery blanket and battery maintainer and it’s always started. I’ll probably attempt the same on the Volvo but it’s tight around the battery so we’ll see. The dealer said they do offer something similar so I’ll look into it more towards fall. For now, I want to experiment with which oil will provide better protection. Can’t easily turn off the stop/start unfortunately which I don’t likeAt that temperature I’d have a supplemental heat source such as a block heater. You’re pushing the pumpability limit of a 0W rated oil.
Pumpability is your concern and not really testable by you, unless of course it doesn’t pump and your engine fails. If you really are starting at those very cold temperatures I’d suggest a boutique oil with a high PAO content such as from HPL. Or at least an oil with a known inclusion of some PAO such as the Mobil 1 ESP suggestion above.As far as I know it isn’t an option. Same with our Tiguan, but we have an oil pan heater, battery blanket and battery maintainer and it’s always started. I’ll probably attempt the same on the Volvo but it’s tight around the battery so we’ll see. The dealer said they do offer something similar so I’ll look into it more towards fall. For now, I want to experiment with which oil will provide better protection. Can’t easily turn off the stop/start unfortunately which I don’t like
I'd move, personally.With mornings of -40 to -45C not including windchill which would you choose?
it is a true statement despite what the armchair lawyers tell you.It so frustrating to read this over and over and over and over and over and over and over.
It has everything to do with it, damage is the operative word. Your post is just fear mongering for no reason.it is a true statement despite what the armchair lawyers tell you.
It's in the warranty that you must follow the "recommended" maintenance. If they "recommend" 5W-20, they can void the warranty for using xW-30. Got nothing to do with whether or not the oil caused the damage. It's the verbiage used to weasel out of everything.
Doesn't matter what they do in Mexico or Uganda if you bought your car in the USA.
I realize I could be in a fight for warranty. There’s a way around everything - I can just keep one of my 0w20 oil drains and pour that into the engine if something catastrophic happens. All I need is receipts for approved 0w20 which I have.it is a true statement despite what the armchair lawyers tell you.
Correct, I mentioned Pennzoil in my first post. Mobil 1 is also on sale currently with a rebate on top of that if I buy 3.I suspect you're in Canada. This is regularly on sale. It's Shell Helix Ultra sold around the world. Buy it.
Run ESP 0W30.With mornings of -40 to -45C not including windchill which would you choose?
Have you no sense of adventure? I also didn’t say Volvo wouldn’t see it every 16k or 1 year for the first bit. When was the last time you saw a new vehicle catastrophically fail? GM aside.Volvo has strict inspections for warranty requirements. The OP is foolish to change the oil on his own-or use any oil other than what's stated in the owners manual. There is no middle ground here. Every ten thousand miles there is an oil change required and various items that are to be inspected.
They dont catastrophically fail. I just had a some work done under warranty regarding a leak. Had to have one of the motor mounts loosened and the leak repaired. You screw around with oil grades you leave yourself open. You are not driving a Ford or Chevrolet anymore. Volvo has their requirements.Have you no sense of adventure? I also didn’t say Volvo wouldn’t see it every 16k or 1 year for the first bit. When was the last time you saw a new vehicle catastrophically fail? GM aside.
So, get a block heater. Quit searching on line and go talk to the parts guys. The engines are all the same - so, if it fits the XC-90, it will fit your car.Makes a difference in Canadian winters with no block heater
Please post these strict warranty requirements that require a specific grade to preserve that warranty.Volvo has strict inspections for warranty requirements. The OP is foolish to change the oil on his own-or use any oil other than what's stated in the owners manual. There is no middle ground here. Every ten thousand miles there is an oil change required and various items that are to be inspected.
Look I own a Volvo. I'm not getting in a spitting contest with a topic that has been beaten to death. Do you own a Volvo? I just had some big buck repair done-under warranty (2022 XC60). If you want to gamble because you think you know better than the engineers who design these (expensive) vehicles-go right ahead. It's also a warranty issue that covers the vehicle bumper to bumper with inspections along with that oil change (As I stated earlier.)Please post these strict warranty requirements that require a specific grade to preserve that warranty.
Maybe that’s what the ‘Defa’ the salesman was referring to when I asked about winter prep items. That’s a September/october issue to look into…So, get a block heater. Quit searching on line and go talk to the parts guys. The engines are all the same - so, if it fits the XC-90, it will fit your car.
For the 2026 Volvo XC40, a genuine Volvo electric engine heater (part #31373621) is available to preheat the engine coolant, reducing wear and improving cold-weather starts. This auxiliary electric heater, which often includes a front bumper-mounted socket, warms the engine to roughly 20-30°C above outside temperatures.
If you really want an oil that will flow at really, really cold temps - then get this one:
https://www.advlubrication.com/coll...ssenger-car-engine-oil?variant=40941311688897
With a pour point of -60C - it should cover your winters.
Who says you have to tell them about the oil change?Look I own a Volvo. I'm not getting in a spitting contest with a topic that has been beaten to death. Do you own a Volvo? I just had some big buck repair done-under warranty (2022 XC60). If you want to gamble because you think you know better than the engineers who design these (expensive) vehicles-go right ahead. It's also a warranty issue that covers the vehicle bumper to bumper with inspections along with that oil change (As I stated earlier.)
