This happened to me a few times over the last few months and it is becoming an unpleasant issue.
When I make this left-turn in my 20 Ram 1500 5.7, about the halfway thru the turn, the rear-end will lose traction (slide-out). This happens in wet weather when the ground is wet; there does not need to be any standing water. During the most recent experience, the rear-end slid-out almost 45 degrees!
Each time it has happened, I was only accelerating gently and my speed was around 15 mph when I reached the halfway point of this turn. Yes, it only seems to happen at this intersection....possibly due to the slight incline?
My tires are the original Goodyears with 8/32" remaining. Tire pressures are 2 psi over the door jamb sticker. Truck bed is usually empty.
Is this a situation of driver error or do I need to consider different tires?
