https://www.govinfo.gov/content/pkg/CFR-2011-title49-vol6/pdf/CFR-2011-title49-vol6-sec571-139.pdfMax Pressure: For passenger car tires. the max pressure is NOT where the load maxes out. For SL (Standard Load) tires, the load capacity maxes out at 35 psi (for Eurometric tires: 2.5 bar = 36 psi!), and for XL (Extra Load), the value is 41 psi (Eurometric: 2.9 bar = 42 psi!) Note" you will find tires that list a 35 psi max pressure - in which case the max load does max out at the max pressure.
T - Capriracer is a tire engineer.https://www.govinfo.gov/content/pkg/CFR-2011-title49-vol6/pdf/CFR-2011-title49-vol6-sec571-139.pdf
"Maximum load rating means the load rating for a tire at the maximum permissible inflation pressure for that tire.
Maximum permissible inflation pressure means the maximum cold inflation pressure to which a tire may be inflated."
Now, I know that's government speak, probably written by folks that had to look up "tire", but I have to associate the two, as they did. Better source?
There is no tire you can buy where the maximum PSI rating is under 50. They do this because idiots overinflate tires way higher than they need to be because they "think it looks too low"So if the door label said to run them at 35 psi, then whats the sense of buying tires rated to 51 psi?. Plus not understanding how the tires will perform BETTER carrying max loadsm with higher pressure, is extremely uninformed on your part. Glad I could help you understand that.,,
You should never have to adjust pressure more than +/-3psig from placard to achieve safe load and handling and ride on a passenger car for it's normal intended usage; If you do, you bought the WRONG TIRE.The recommendation on the door, was put there to match the tires installed at the time of manufacture. That being said, his new tires do not have the same pressure ratings as the tire they put on the car in 2008. The manufacturer of his new tires say what it can it be inflated to. New tread design and capacity determine what you can inflate them to. New tires may look low on pressure if inflated to what the door label says, and may feel like they drag, going around corners. Filling to max capacity probably will make for a rough bumpy ride, if not needed. And no I've never seen a tire brand and type written on a sticker, that's why you can't assume every tire ever installed on that car has the same inflation requirement. I hope that clears this up for you.,,
You're the one not getting it. The door label tells you what the pressures for YOUR particular car are, and the tire's sidewall shows what the tire's maximum capacity is.So if the door label said to run them at 35 psi, then whats the sense of buying tires rated to 51 psi?. Plus not understanding how the tires will perform BETTER carrying max loadsm with higher pressure, is extremely uninformed on your part. Glad I could help you understand that.,,
^^^^ Folks - I have done this for decades and have always owned multiple vehicles … Many types … Towed and off-road. Plenty cars too. The OEM did not grab that PSI/kPa number from left field. You might also note that tires are one of the longest sections in your owners manual … Think about that …Good post as always. I tend to be a plus one tire shopper. Like a bit more width because I’m on sand often. Like some sidewalls because (as handle implies) - drive 4WD’s and they don’t ride well on low aspect rubber, not compliant off-road (and wife will curb gouge the rims) … And yes, like the look.
Have always used the OEM pressure on the plus one and if I get 40k it’s enough …
Uh what? there are plenty that spec 44psi max. without even looking hard.There is no tire you can buy where the maximum PSI rating is under 50. They do this because idiots overinflate tires way higher than they need to be because they "think it looks too low"
Please go back and read the stuff in CapriRacer's posts. It's clear that you don't know what you don't know.Welcome to 2024, where most tires that came on your 2010 vehicles , are no longer in production.They have been replaced with tires that will be used on alot of different vehicles, with different operating pressures. And I know there are some here that want to stomp their feet and not believe that's how it is. So for those who believe what their door sticker says is law, enjoy your new tires that always look like they're going flat. And totally ruin the ride and handling, by running 32 psi in them.,,
Cant believe how many times this comes up....The sticker on your door jam is what you use for the tire pressure NOT the max pressure listed on the tire....Recently replaced tires on 08 Mustang with the recommended tire size. Decal inside door states 35psi, tire states 51 psi. Im clueless. When I checked pressure tire dealer had filled 35, I increased to 45 (just could not bring myself to do over 50psi )
More unbelievable that someone picked up where they left off - and many people share roads with them …Cant believe how many times this comes up....The sticker on your door jam is what you use for the tire pressure NOT the max pressure listed on the tire....
Future daughter-in-laws grandfather would always fill his and family members tires to the max on sidewall. He would reprimand them for not checking and being low. All of their tires had like 1/2 the contact patch, were poor in rain and snow, vehicles rode bad and wore out the middle tread very quickly.
It's there any kind of reference or formula available to derrive an approximate and appropriate pressure when changing tire sizes given the factory size and pressure?In the old days, it was common for car manufacturers to specify the pressure listed on the tire's sidewall. Grandpa is probably remembering those days.
In the 1970's, government regulations stared requiring a sticker - commonly called the placard - with the tire size and specified pressure for the vehicle. At the time, pressures on the sidewall were "Rated Pressures" - meaning the pressure where the rated load maxed out.
About the same time, car manufacturers started using pressures other than what was specified on the sidewall.
Fast forward to today, and it's even more complicated as the max pressure is now listed on the sidewall and not the rated pressure.
The good news is that if you look at the tire sticker and use the size listed there, the load tables haven't changed since ....... ah ...... well, forever. They remain the same. Tire sizes have changed, but the relationship between load and inflation pressure for a given size hasn't - which is why you need to pay attention to the size. Not only does using the right size prevent the tires from rubbing (Very bad!!), but that means the pressure listed on the sticker is applicable as well.
