The recommendation on the door, was put there to match the tires installed at the time of manufacture. That being said, his new tires do not have the same pressure ratings as the tire they put on the car in 2008. The manufacturer of his new tires say what it can it be inflated to. New tread design and capacity determine what you can inflate them to. New tires may look low on pressure if inflated to what the door label says, and may feel like they drag, going around corners. Filling to max capacity probably will make for a rough bumpy ride, if not needed. And no I've never seen a tire brand and type written on a sticker, that's why you can't assume every tire ever installed on that car has the same inflation requirement. I hope that clears this up for you.,,
