4wd
$50 site donor 2026
Yep. And I toss those at 40k …1ST mistake was buying an 80k mile tire. There are compromises to get that long of a treadwear. I prefer 50k or less tires and always get smooth ride and good handling.
They do have a taller sidewall by a 1/4 inch. Not much, but thought it would help. 225/70/17 is non existent and a 245/65/17 is getting g into much heavier tires. Hence I went 235/65/17.If you wanted a softer riding tire you should have gone with something with a taller sidewall. I am unsure how you figured a wider tire was going to help.
tire is 4.5% wider hence has 4.5% more loadbearing area and hence needs about 4.5% less air - so now your at 2psi less. You say it rides pretty much same at 3psi less so that plus a stiffer compound is likely logical.
You should try a tire with a taller sidewall, although a 65 series sidewall is reasonable now days. Sounds like the suspension is just too stiff for your liking.
My experience with several sets of passenger and truck tires by Bridgestone has been exactly the same as @MParr. Harsh riding and poor traction in foul weather conditions. They actually seem to ride harder as they age...maybe due to a harder rubber compound closer to the belts/carcass? I will not willingly purchase Bridgestone tires again.Every Bridgestone tire that I have experience with have all ridden harsh. The higher the mileage rating and added LRR make them a no go for me.
Stay away from Michelin Primacy Tour A/S. The Defender 2 is a good tire however, you will still experience some harshness.
Yokohama Avid Ascend LX might be a good fit.
Goodyear Assurance ComfortDrive is another good pick.
I'm looking at tires for my 17 CX-5. I am looking at the 245-65-17 as they are wider and taller sidwall. Mine rides fine on the Hankook tires, they just don't seem to last.They do have a taller sidewall by a 1/4 inch. Not much, but thought it would help. 225/70/17 is non existent and a 245/65/17 is getting g into much heavier tires. Hence I went 235/65/17.
I would like to hear more on the Koni shocks. I've been eyeing them. Can you elaborate?I have a Milton dial gauge. Should be dead accurate.
Struts are Koni Special Active with like 5k on them. Ride comfort oriented strut.
Got new wheels too. Sparco Assetto that weight 7 lbs less than stock.
All this was to help ride comfort.
It rode ok with all of the above and the Geolanders.
It rides good at 31 psi with the Bridgestones. Bout the same as 34 with the Geolanders.
Lesson learned. Just leave it stock!
Bilstein B6/8 works similarly, except they are performance-oriented. The difference between Bilstein and KONI is robustness. Bisltein is just a more robust shock.I would like to hear more on the Koni shocks. I've been eyeing them. Can you elaborate?
Unfortunately you can't get a 225/70R17. Adding width is going to add a bit of NVH, all else equal.I have a Milton dial gauge. Should be dead accurate.
They are hard tires for the mileage.Ok. I got some 235/65/17 Bridgestone Turanza Everdrive tires for my 2016 CX-5 in the hopes the little bit bigger tire would have some more cushioning since the roads here are atrocious. Stock size is 225/65/17.
Tire Racks reviews of the new Bridgestones are excellent. Supposed to be very comfortable over bumps, great in snow, best in group on ice beating all the AW tires. 80,000 mile tread warranty. Thought they’d be perfect!
Uh, anything over 30 psi and it’s like I’m rolling in Flintstone tires! Atrocious! Like lead filled baloons.
So I did some investigating, using online tire pressure calculators etc.
Since these tires are 104H rated at 44 psi max, while most other tires have a max of 51 at that load rating, coupled with the crazy high mileage warranty, does that mean these are just a super hard compound tire with stiff sidewalls?
None of this makes sense!
With the low max psi, all the online calculators and some hand calculated formulas indicate 30 psi. Door placard is 34 psi.
I’m stumped!
I actually tried 16s and they rubbed on the very top of the steering knuckle! To get 16s to clear I’d have had to get like 30 offset wheels.Im genuinely curious why you bought new wheels that were still 17"? If you are looking for ride/comfort go down at least to 16" and get a 225/70R16. More sidewall and less wheel will always improve ride while sacrificing some handling. Ive gone with smaller wheels and seen a huge improvement in fuel economy and ride. Unsprung weight being the enemy as you already know.
They’re the special active struts that have the valve that opens up on hard impacts to soften up, but stay stiffer in corners. Meh. They were ok when new but honestly after having so many different brands of aftermarket struts on cars, I’m always gonna stick to OEM. They just work the best. The Konis are alright. Better than blown out old ones. KYB are too stiff, Monroe’s were always too soft IMO.I would like to hear more on the Koni shocks. I've been eyeing them. Can you elaborate?
