Plugs get all poofed out inside the tire like a wad of chewing gum. Much bigger than the part that sticks out of the exterior of the tire. Air puts the same pressure on them that it does the patches.....Prefer to fix holes in my tires with something that the air pressure is trying to keep the hole closed, over something the air pressure is trying to open the hole back up. But I have all my own machines, so it's way easier for me.
That’s literally the ONLY area I’ve seen a plug fail-that’s too far out-too much flexing there!Discount Tire wanted $300 for a new tire on my Genesis in August, so I plugged it.
I figure I would have had to replace the tire anyways. So if it fails, I don't have much to lose.That’s literally the ONLY area I’ve seen a plug fail-that’s too far out-too much flexing there!
Yes, safety standards and requirements have changed over time.And before patches were developed, plugs were considered the standard and acceptable.
Just to point out that you're now scraping away/damaging an area of the liner inside the big circle. You are now dealing with a much larger area that has to have sealant (which a plug provides) smeared over the top of it. A little layer of sealant on an area at least the size of a quarter - which is a couple of inches of liner protected by that little thin layer of sealant.That's not likely the biggest issue, which is that the liner has been punctured and even if the plug is perfect, the liner may still be breached. The liner needs to be properly sealed from the inside. Of course a patch needs a buffed area (which scrapes away the liner) on the inside of a tire to properly adhere since cement doesn't stick well to the liner material. But then a sealant can be applied to the buffed area to create a new seal. It can look pretty ugly, although I suppose gooping it all over is better than being light on it and maybe missing a spot.
Sure you can know that. Does the plug hold air? Then it poofed out. Have you ever seen a plug that hasn't poofed out? Can the internet show me one that hasn't poofed out?Can't know that for sure without removing tire and looking at it, then might as well do correct patching.
I prefer the patches that actually fill the hole also. Even this smaller patch puts 83 lbf on patch @ 40 PSI tire pressure,
which no plug will get close to.
Xtra Seal | Lead-Wire Patch / Plug Combo 3/16″ (13-672)
Xtra Seal Patch Plug Combo (3/16") (13-672). 13-672. Plug Stem Repair. In Stock. Call or Click Today! FREE SHIPPING on orders over $25! 1-855-550-2626.tiresupplynetwork.com
To each his own of course, but I figure I already cheaped out on not buying a new tire, not going to cheap out on the patch method too.
(of course as a temp fix, no problem with plugs).
My biggest issue is the little tubes of cement drying out when stored.
Moreso the various lawyers who have all sorts of disclaimers and whatnot under the guide of safety. The tire industry is all for it because it allows them to sell more tires, despite the fact that modern tires are way higher quality than we give them credit for.We use to be a proper country till the insurance industries ruined it....
The only question on my mind is the switch to no longer including contact cement in the kits. I just plugged two tires without cc, we'll see it they hold air well. I would think the seal would be better with contact cement, but the plug likely spreads through the hole just fine without it. And if I had any concerns with the plug failing due to age, I suspect it would be because the contact cement starts failing. So maybe no cc is better in the long run.
I've had 11 year old tires get damaged/fail while offroading or carrying kayaks on a roof rack. These tires were from 2012 and I replaced them about a month ago. They spent their whole life uncovered in the Phoenix Arizona sun. Tires definitely last longer (age not miles).than people thinkMoreso the various lawyers who have all sorts of disclaimers and whatnot under the guide of safety. The tire industry is all for it because it allows them to sell more tires, despite the fact that modern tires are way higher quality than we give them credit for.
Examples of industry over-exaggerations:
- Can't plug a tire
- Must use a winter tire when it's below 7C
- Must replace tires >6 years old
Is there technically a basis behind these statements? Yes. Is there any real substantial and practical difference accounting for a variety of other factors? eh....
