Tips for getting front bumper back in shape after minor impact ? (Prius Prime 2017)
Hit an object on highway last week heard a bang just like rock to the windshield except the the windshield was fine.
A few days later my wife asked if I hit a curb that's when I noticed 4 inch indentation on the bottom passenger side front bumper, and gap in front with a bulge on the side and the light bulb went off that this must have been bang I heard on the highway.
In the wheel well we see the front clips have a few min shaved off and to creased where the plastic folded are visible creating an outward bulge.
Sent pictures to a local body shop and they quoted between $1800 to 3000$, I think they had have estimated the replacement of the entre front bumper and a paint job. Not going to spend that kind of money for something this minor.
I removed the bumper and no damage to the head pump that's just in that area :
I could not resist washing off the exposed area and blow drying afterwards.
My question, - any tips for getting the bumper back in shape the creases out from the side ?
For the missing tabs I going to try and extend them with epoxy made for car bumpers.
Not really concerned about the front bottom damage as this car is very low. The front bumper is away prone to scrapping stuff and acting as a plow in winter.
Picture of the undamaged taps on the driver side, not much is missing on the left.
For the busted tabs you could drill holes in the side fold and use zip ties for drift stitching. Noone's going to see it in there. As for the creases, maybe a little heat from a hair dryer?
As a fellow Prime owner, yowza, I had no idea they hid all the AC stuff behind a flimsy bumper cover right in the corner. I'll be careful out there!
Agreed on heat to see if you can destress it.
Those clips in the wheel well are a weak spot and are prone to fall apart. This stuff can be hard to even plastic solder / remelt with any kind of strength. There could be some room for creativity with a homemade bent-aluminum bracing and a rivet gun?
Found the entire dumper breaks down to smaller sections and if I screw up I can get per-painted parts.
But 1st I try to remove crumple with boiling water then I will try the heat gun from the inside and knowing my luck I will just burn off the paint and 100% ruin the part.
