Thoughts on redline?
Great articles! I "rev with abandon"
I use 0w40 in Z3 with the M52TUB25
5w40 in E46 330i with M54B30
And a mix of 1:2 with 5w50/10w60 in M3 V8
Since they're MT cars, use MTL
Also their rear diff fluids
Originally Posted by buster
My thoughts have changed a bit over the last month regarding SA and GDI engines. I don't think SA is as much of an issue with GDI engines. You often find those that have used oils like Red Line, that contain significant ester content, the engines remain remarkably clean, especially the ring area which is prone to carbon buildup.
If it is true that the higher moly, ZDP and ester content help mitigate LSPI issues, than Red Line could very well be a top choice for GDI engines. The low Noack and high solvency could really be beneficial.
This is the issue when calcium is reduced LPSI is reduced. Molybdenum and ZDDP can counter LPSI if calcium if high. It turns into a circular solution.
