- Joined
- Feb 8, 2022
- Messages
- 1
2003 Ford Ranger 4.0 197480 miles. Everyday driver
That’s amazing. Can you please refresh my memory regarding what type of CVT fluid you were using ( Castrol? )433,433 miles...
Died today. Cvt transmission finally went. Starts, moves but is doing the rpm dip as gas is applied. Its okay stuff happens..... Rack and steering were getting shaky, still leaked, rust, cracked windshield, etc. It is what it is. Im sad
but its gonna be okay. Hopefully Peugeot will demo me a car, not getting another Honda unless its a motorcycle
or dirt bike
Red Line most recently. I think it was his favorite but he’s run others too.That’s amazing. Can you please refresh my memory regarding what type of CVT fluid you were using ( Castrol? )
Thanks
So much for shortening the life of a CVT by using non OEM fluidRed Line most recently. I think it was his favorite but he’s run others too.
Looks pretty dirty. Lot of carbon.2000 Honda S2000 with 230,500 miles. I’ve personally put about 130,000 of those miles on it over the past 15 years, and for a while it was my daily driver. I had a job that required weekly state-to-state travel, so the car saw a lot of highway miles and I did 10,000-mile oil change intervals.
Back then, I had stocked up on AutoZone sale Mobil 1 0W-30 AFE and ran that almost exclusively for roughly 120,000 miles. These days, the car only sees about 1,000 miles per year, and I run Amsoil with annual oil changes.
A few oil changes ago, I unfortunately over-torqued the drain bolt and stripped the oil pan threads. Rather than repair it, I decided to drop the pan and replace it.
At 230k it looks fine. How much oil did you add between 10k OCIs?2000 Honda S2000 with 230,500 miles. I’ve personally put about 130,000 of those miles on it over the past 15 years, and for a while it was my daily driver. I had a job that required weekly state-to-state travel, so the car saw a lot of highway miles and I did 10,000-mile oil change intervals.
It's been awhile but around a quart or a little more. The car never smoked but these things are turning 4500 ish rpm @ 70-75 and use oil. I did those 130k miles in the span of about 2 years then the car sat for several years with little to no use. I've had the valve cover off several times and the engine is clean up top.At 230k it looks fine. How much oil did you add between 10k OCIs?
Do you burn any oil?2002 Ford F-150 XLT extended cab FX4. 4.6 liter, 2 valve engine. 156,300 miles and just changed my oil from Havoline Pro DS 5w-20 and started using Amsoil high mileage 5w-20.
AMSOIL Signature Series 0w40 in my 2012 GM 2.4L ECOTEC with 227k miles. These GDI engines are known for eating chains, carbon buildup, oil consumption. No such problems with 10-13k drain intervals.I'm posting this in this section instead of the General section because it definitely has a lot to do with lubrication.
I just wanted to see how many people here have over 150,000 miles on their original engines, to see what kind of oil you've been using and what kind of intervals.
We talk about a lot of different oils on here, and critique a lot of used oil analysis, but the absolute best way to find out if any particular routine works, is to look at those people who have had success with it by getting long life from their engine! That is truly what we are all trying to achieve here.
So if you've owned your car since new (or at least know the exact prior history of it from new), please step in and give us your input!
I think this could be a very interesting topic!
Have you run that since new? Agree a lot of people seem to have trouble with that engine.AMSOIL Signature Series 0w40 in my 2012 GM 2.4L ECOTEC with 227k miles. These GDI engines are known for eating chains, carbon buildup, oil consumption. No such problems with 10-13k drain intervals.
