For the 03 Envoy with its 4.2 I6 ive been posting about with the SES light recently. I sort of agree with you all. The mechanic 1. knows what the code is and 2. Has a WAG based on the constant 160-degree temperature that the thermostat is "failing open" as opposed to failing shut and overcooling not overheating the engine. I am tempted to pick up a scanner for ~$100 any recommendations? I know the car is OBDII at least i think that it is.
And, unrelated to that.. Is my hypothesis correct ? The SUV stays at 160 degrees and does not BUDGE from there. She could be doing 80 on the highway (she only does 75 tops) or driving the hour each way to work every single day, it does not move from there. So, based on this, i told her that: 1. If the engine is overcooling, the computer thinks it has not fully warmed up. Therefore, it sends more fuel to the engine, thinking it is cold. Operating the vehicle for ~2 hours every single day as has been the case for the past few months including long distance road trip, usually more, is really sludging up the engine, since the oil cannot get up to its full temperature even if it is 5w30 (I find out soon. I will not be able to have her tell me what the mechanic said the code was. And i tried earnestly.) So, i am saying she is 1. wasting gas AND 2. sludging up the engine. Mechanic feels the $500 T-stat job will solve the problem. And, my question: The truck runs at 160 degrees it is supposed to be in the middle at 210 degrees, is this a problem to 1. Sludge 2. Fuel economy 3. The whole engine? Has been this way since Fall 2011. 142,500 miles. Thank you!
Also.. she changed her mind. She WAS going to get the $500 t-stat work done today. She put it off until next month.
I tried, earnestly. I tried my whole best. It didnt work. (Next month is a maybe on the work as $500 is sort of a lot.)
Maybe just maybe if i can pull a code.. well it wont change what she and the mechanic will do, but at least i would know.
Should i bother to get the scanner and find out the code when i am then powerless to act on the information it provides!? What would you do here. ?
