Originally Posted By: Ken2
10W-40 oil is bad news. Always has been. If it is conventional oil, it has too much viscosity spread (30 points) and that requires too high a proportion of viscosity index improver polymers. These do not lubricate. They make the oil thick when the viscosity is tested hot flowing through an orifice, but the oil does not protect as well as an oil truly this viscosity without the VIIs. When the VIIs shear, you don't even have the illusion of the higher viscosity.
Avoid 10W-40. If you feel the need for a 40wt oil, get a 15W-40 or 5W-40. If all your engine needs is a 30wt oil, get any of the many top quality 10W-30 or 5W-30.
In the 1970's, that may have been true.
Today, it is not. Modern 10W-40's are excellent oils for certain applications.
Look on any PDS sheet - 10W-40's and 5W-30's often have close to the same viscosity index. BUT, I'll bet the 5W-30 uses MORE VII's, as it starts with a thinner base oil.
By your logic, that should make 5W-30 'bad news' LOL!
