Originally Posted By: nap
Gokhan, can’t you read?
https://www.infineum.com/media/80723/api-engine-oil-classifications.pdf
Page 2, Footnotes 1 , 2 and 15. Exemption 2 and 15 are for the non RC oils as you mention. However, exemption 1 is for 0W20, regardless of whether it is RC or not. Now check the TEOST 33 line and it has exemption 1 in addition to 2 and 15.
So 0W20 is exempt solely on its viscosity, regardless of its RC or starburst status.
No,
you can't.
Read carefully and pay attention so that
what you read makes sense and you don't interpret things incorrectly as you did. Your eyes are reading but your brain is not paying attention the detail.
These are the requirements for API SN-RC (SN with Resource Conserving),
not for API SN without RC (without Resource Conserving):
Now, this is the table of the footnotes that has been confusing you. The key sentence here that you should have paid attention to but you have not is at the very top and is in large print:
"Requirements for API SN are the same as those for API SN-RC, except as noted in the table to the right." What they are saying is that the exemptions for API SN without RC (without Resource Conserving) are noted in this table. The exemptions for TEOST 33C that keep confusing you are:
Exemptions for TEOST 33C:
(1) Not required for SAE 0W-20.
(2) Not required for SN Non-ILSAC GF-5 viscosity grades (non-ILSAC viscosity grades are xW-40, xW-50, and xW-60).
(15) Not Required for SN ILSAC GF-5 viscosity grades (ILSAC viscosity grades are xW-16, xW-20, and xW-30) which do not also contain the API Certification Mark or are not SN-RC.
So, not only 0W-20 is exempt from TEOST 33C but all non-ILSAC SAE grades -- all xW-40, xW-50, and xW-60 -- are exempt from TEOST 33C.
TEOST 33C test means turbocharger protection. From the
API motor-oil guide, Resource Conserving means "API SN with Resource Conserving matches ILSAC GF-5 by combining API SN performance with improved fuel economy, turbocharger protection, emission control system compatibility, and protection of engines operating on ethanol-containing fuels up to E85."
How do you expect to have the Resource Conserving certification and API Starburst on a bottle of motor oil if the requirements of Resource Conserving, including the turbocharger protection, are not met? This would make absolutely no sense whatsoever. A consumer would be sold a bottle of oil that claims to have turbocharger protection (Resource Conserving) but due to some obscure footnote regarding turbocharge protection in an Infineum brochure that is often misinterpreted by some people, it actually wouldn't? Now, how absurd that would be!
As a final note, which I emphasized before, the high-moly exemption for 0W-20 is no different than the high-ZDDP (high-phosphorus) exemption for xW-40, xW-50, and xW-60. The latter are non-ILSAC grades and are exempt from TEOST 33C and ZDDP-maximum requirements of Resource Conserving and the former (0W-20) is an ILSAC grade but it's still allowed not to have the Resource Conserving requirement of ILSAC and drop the API Starburst and Resource Conserving and satisfy API SN only if the manufacturer chooses to load it with moly. However, high-moly (700 - 800 ppm moly) 0W-20's are mostly from the API SM era, which didn't have turbocharger protection, and I'm not aware of any high-moly API SN 0W-20 that doesn't have the Resource Conserving (API Starbust) and therefore chose not to do and/or pass the TEOST 33C turbocharger-protection test.
Is this finally clear?
