0w40 is significantly thicker at 0 degrees than 0w20.Only if you use the wrong "W" rating for the cold starting conditions you're in.
It's still a "0W" rated oil ... so I wouldn't call it significantly thicker. If it was that much thicker it would have a different W rating.0w40 is significantly thicker at 0 degrees than 0w20.
I've never said that every branch of an oiling system gets "equal flow" of oil flow. I'm sure you understand that each branch flows a volume based on either the volume being forced through it (if PD pump supplied volume) or the resulting flow volume as a function of a fixed supply pressure.Look at your showerhead as just a funny branched system not guaranteein g equal flow through the individual nozzles, PD or else. PD has no chance of sending as much fluid as high in jet 1 as in jet 2 and jet 3. I never made up much more analogy than that but understand that you like the arteries and heart chambers even less ;-)
Why not read a line or two from time to time, need not be mine, just something beyond the troops'.
You keep bringing up shower heads ... oil cooler jets are essentially a flowing orifice. If you increase or decrease the flow through the jet (regardless if PD forced or pressure supplied), the jet will go up or down proportional to the pressure. Just like when you increase or decrease the supply pressure to the shower head - each jet will go up or down proportionally to the supply pressure going up or down.Showerheads for piston cooling jets including funny free pressures for travels into and throughout the piston – please take them over there, that linked thread is still open.
Take strokes and coronaries for pushrods and lifters now ;-) And a heart as a positive displacement pump. Or just read up elsewhere if you prefer. Actual data can be found, right? Even regarding engines as if those weren't much less important than Adonisissies hearts.
How old is that study? -20 F is pretty cold. Four of those oils tested had a pour point of -20F, which basically means that they almost stopped flowing via gravity all together. Even though all those oils are supposedly "10W", it's evident that their specific formulation is causing different pumpability in that specific engine.Different thread, different papers – still times in minutes. Funny world out there:
Re: The bolded sentence. You're using examples where pumpability is right on the edge of a high degree of degradation. They tested oils that were at or not far from their pour point. Look up what pour point means ... it essentially means the temperature where the oil won't move under gravity. This causes all kinds of pumpability issues - and most of the pumpability issues are simply getting the oil sucked into the inlet side of the pump. The exact oil pick-up and oil pump (including its pressure relief setting) can have a big impact on what goes out the pump to the oiling system under conditions like this test. The real test of the pump performance would be to take all those inlet pumpability factors out of the equation.50 years, but they already had positive displacement pumps not guaranteeing positive displacement distribution, fundamentals are fundamentals to accept. 40 psi were a threshold in measuring, that's easily enough to get their ideas and discard the own.
Different engines are different all the time, younger than 50 years they for example can use capped pressures from idle to redline which only means no compensation over rising pressures. That fact alone annihilates half of the other thread if one only begins to accept realities.
Here the common points are PD doing nothing for anything but total flow through the pump, although they clearly state that it's not a "pumpability" problem on the suction side, and ratios or biases shifting in branched systems. Therefore times to lubrication are of interest and PD ideas shoving is not. It's plain wrong to ever consider "PD" a clincher for anything beyond the first ramifications.
How do you explain the gigantic test difference in time between the two runs of Oil L under the same exact test conditions? Something going on there, and that's what can happen when the oil is basically on the verge of loss of pumpability. Then look at Oil G where there had to be 100% full pumpability in order to achieve 2 sec to 10 PSI and 6 sec to 40 PSI at -20F. Same deal with Oil R which shows complete pumpability. It's not necessarily a PD pump issue when the performance to achieve pressure is poor at super cold temperature and almost non-flowing oil ... it's the lack of flow into the pump inlet so it can actually have some oil to pump. Remember, this is all on the same test engine so same PD pump.Read the pic, it's all there. A PD and ramification are like an open diff, like a mobilé, like ...n'importe.
You never answered my request in post #54. Tell me why Oil G and Oil R worked perfectly fine at -20F while many others didn't. I said why - because if you can't get the oil into the PD effectively (the oil's "pumpability") then you don't get the proper volume amount that the pump is mechanically capable of pumping out. It's pretty obvious that with Oil G and Oil R, there is 100% pumpability. The oils that show much longer pump-up times (like Oil L, M & P) are showing the lack of pumpability.You aren't asking me me me to explain Table 3 first? Same wonder as last time when a mere -15°C made a difference between 5W-40 and 10W-30 at the rocker arms but made none of you want to explain.
PD needing several minutes in -15°F – whatever your PourPoints – once more illustrates the nature and worth of PD ideas around. Unless we and our J300, CCS, MRV and Brookfield begin to tell people that 10W is great down to -15° Whatever because minutes aren't hours. After all we have positive displacement pumps, positive displacement pumps would never allow minutes to become hours – you discard the idea.
