This isn't to start a hectic debate or condemn anyone, but I'm curious what everyone thinks about the use of a 5W motorcycle oil, like Rotella T6, Castrol Power RS, Motorex, etc ? I've been contemplating the use of T6 in one of my bikes after seeing some promising used oil analysis (currently testing out the Rotella 15W40), while also noticing some used oil analysis with higher wear rates (given, this could be due to a range of possibilities from OCI, type of motorcycle, how hard the bike is ridden or raced, etc. which I'm not including in the analysis of the oil).
Given that the T6 has been shown to be fantastic for various gas and diesel applications, I'm wondering if it fares as well for motorcycle use with a shared transmission. Of course once the oil is up to operating temperature it is no longer 5W but equivalent to a 40, but what I'm curious about is during cold start up is the 5W offering enough protection and acting as a thick enough lubricant and providing enough oil film strength to contend with the engine, gearbox, clutch, higher rpm's, and more severe engine conditions when compared to a gasoline/diesel engine alone?
I've looked at nearly every major motorcycle manufacturer from Yamaha, Honda, Kawasaki, Suzuki, BMW, Ducati, etc. and found that out of all of them, BMW is the only one that manufacturers an oil below a 10W (in this case a 5W40) that is to be used within certain year ranges of BMW's. I found many other oils from these companies: 10W30, 10W40, 10W50, 15W30, 15W50, 20W50, but again, no mention of the use of a 5W oil, not to mention the void of the warranty if used during that time frame.
Since motorcycles don't have to conform to CAFE requirements because of their high fuel efficient nature (thus negating one reason to use a thinner oil for improved fuel economy), and since most oil in motorcycles have to not only lubricate the engine, but also the clutch and gearbox, plus the greater demands of the motorcycle itself, is this the reason nearly all the manufacturers mandate the use of at least a 10W oil?
Just wanted to get everyone's thoughts and opinions on the subject.
