Which shows that at 0C, a 5w-30 was significantly heavier than even an SAE 15 lubricant)))))))))))))))))))
yes I see that and your chart only goes to 15 weight, but if you look at it in a graduated scale, I believe a 5w30 would be very close to a 25 weight at 0 celcious. or atleast somewhere close in that range.
I do agree the confusing part, is with differnt temperatures, and how a particular viscosity, behaves cst wise at that temperature , as far as a comparable.
If this does not make sense, then what single grade weight does a 5w30 behave like at o celius, cst wise?
