The Mann OEM Audi filter question
Yep . Bumped into an older discussion :
The most efficient filters shown in that table are 99% @ 38u, and most show to be 99% @ 50u.
I am surprised to see the low efficiency at least what it was. I am sure many years ago the filtering media was way different. I will cut open this filter one of those days and show you what's inside. Maybe I will find very old filter sitting around too.
43.511 PSI is very high, wonder why. Too high a bypass setting could cause the oil pump to hit pressure relief earlier if the dP gets that high, and cutting back pump flow before the filter bypass valve opens.
They do show the 4.3511 PSI above in the bullet info. Slipped a decimal point.
Wow. I did not see the bottom chart where it has different decimal. I only copied the top part. Still high at 3bar(~43.5psi)
I measured the holes on the Mann. It measures around 7.9mmx6.8mm since it is not an actual circle.
Purolator measures 7.1mm hole
What's the total combined flow area of the sum of the holes on each filter. Looks close, which means the hole design doesn't really matter with respect to the dP vs flow performance.
It is not close,but close to double
Let say we take the bigger side for the Mann 4x7.9=31.6
Purolator is 8x7.1=56.8
I am still not going to use the Purolator thou
