43.511 PSI is very high, wonder why. Too high a bypass setting could cause the oil pump to hit pressure relief earlier if the dP gets that high, and cutting back pump flow before the filter bypass valve opens.The by-pass opening pressure of the filter is 43.511 PSI :
https://www.mann-filter.com/us-en/c...t.html/w930/21_mann-filter.html#technicalData
They do show the 4.3511 PSI above in the bullet info. Slipped a decimal point.
