Originally Posted By: GMorg
If you think that most store brands and the established brand name foods are the same (they tend to be nutritionally similar), then Mobil 1 and Super Tech are the same. If you think that there is little comparison between name brand and store brand foods, then Mobil 1 and Super Tech are very different.
The API symbol means that each oil passed the same set of tests. If you needed surgery, would you want the surgeon that passed all of his classes with a C's or the surgeon that passed all of his classes with A's. They both passed the same classes...
This is a little misleading,there is a difference between a doctor making C's and an oil that must meet a set of standard(s) to be certified as API and GF5 approved.With the API/GF5 certification,the oil either meets or fails,a doctor can make a grade from A to D and still pass.An oil must meet the standards set,not make a 'C' etc. but must meet the standards that are set for certification.
While I agree that a doctor with A's will most likely be a better doctor,does an oil with higher amounts of additive 'X' make it that much better?
From the reports we have seen,there is little proof of such in most if not all instances.
We have seen several times here on the board that an oil that is API SN certified and meets GF5 standards would for all intents and purposes,be a good oil.The SN/GF5 standards are high and an oil has to be a really descent oil to meet these standards.
We also have to look at the base oil suppliers,there are really only a few and they make good base oils.
There is also the fact that there are only a few 'add pack' companies and they too make quality products.Afton and Lubrizol probably being the biggest.
Are the lesser 'brands' bad? Not if they are certified.
Are the name brands better? It depends on what you mean by better? Do they work any better? They cost more but do they perform better?
We have seen uoa after uoa of Super Tech oils and they have performed very well.
We have seen uoa after uoa of name brands and they too perform well.
But,have the name brands done anything above and beyond what Super Tech has done?
If we look at the information,Super Tech has performed as well as the name brands.Since it has,why pay more money for something that isnt going to give any better results?
It is possible that a vehicle might not 'like' Super Tech but that can happen with the name brands too.
I have a car that had 8X K miles when I got it,it now has
over 225K miles and much of that has been with 'store brand' oils.
