This is something few shooters think about, and even fewer worry about. But it's a good idea to be at least cognisant of it, because it can happen with factory ammunition, as well as handloads. In semi auto pistols it can becaused by 2 basic factors, recoil, and the slide pushing the nose of the bullet into the feed ramp.
This is the exact opposite of what happens in revolvers, where that same recoil can pull the bullet slightly out of its case as it rotates in the cylinder. In revolvers, (especially in the Magnum cartridges), it can be enough to pull the bullet far enough out of its case to tie up the gun.
This doesn't happen much because revolver cartridges usually have a heavy crimp on them to prevent this. And most revolver cartridges headspace on the rim. But semi auto pistol rounds cannot have heavy roll crimps, because they headspace on the mouth of the cartridge. So a taper crimp must be used. And that type of crimp doesn't provide the "grip" a heavy roll crimp does.
A few thousandths of setback isn't going to hurt anything, but the article below states that a setback of just .010 or more can become a problem waiting to happen. And .035 + has the potential to cause a disaster.
I'm not trying to create fear. But it is something most shooters should at least be aware of. And it's quite easy to check for, by simply eyeballing your ammo before you shoot it.
https://www.recoilweb.com/bullet-setback-fears-160844.html
