NJ went to no emissions test on pre OBD 2 vehicles, Pre 1995. They just do OBD plug in now. They used to do sniffer test on older ones but not anymore.
I don't get how that drive by thing works.
I'm going to go with my Sportwagen would fail ahahahahah. Aftermarket downpipe/high-flow cat...300CEL I believe. You can smell it so I know it's not passing that way. What do they do if you go through it and don't live there?It uses a beam of infrared light; the vehicle emissions scatter the IR light, and a detector measures the amount of scatter to determine the amounts of CO2, CO, and HCs present.
https://www.opus.global/vehicle-inspection/remote-sensing/
Like most things like that: nothing. If I leave SC where there is no inspection and no sticker and drive to PA or anyplace requiring inspections and stickers, or to a "pass by sniffer state", no fine for me.I've never found an answer to that one.
Mobile emissions testing equipment is being set up at busy intersections in Northern Virginia. The new technology can measure tailpipe emissions and snap a picture of the license plate of the offending vehicle just as easily as a speed camera can catch speeders. If the vehicle is from Virginia, they will be required to get an emissions test regardless of what county they are from. If they are from out of state there may be jurisdictional problems, but at least we will know where the pollution is coming from.
Drive by sensors sounds extremely inaccurate.
I’ve probably driven past 100’s of them over the years and I always take my foot off the gas and coast past them. I’m not sure if it makes a difference or not.
The driver behind you probably notices a difference and wonders what you're doing?
Haha probably not. I always speed up a bit before and accelerate again as soon as I completely clear the green box.
I actually had a car of mine pass it's emissions test by driving past one of those. Still had to pay $30 but at least I didn't have to take it in for the test.
I don't drive past them anymore since they don't put them in the places I drive these days.
You can then put tiger hair over the metal patch, and spray it with undercoating perfect repair!I remember my first car failing inspection here in VA ('67 Cougar my dad gave me in the late '80s) b/c it had a rusted hole in the p. side floorboard. I riveted a license plate over the hole and it passed. AHAHAHAHAHA
I live in Ohio yes they are bad a lot of them are!Very true. Those Ohio cars are in the worst shape of any I have seen. Really bad.
I’m not sure if this has been covered, but at one time did Virginia have safety inspections twice a year?
I'm in Maine and have my state inspection license from when I worked at a shop. Maine is definitely a rust state and generally vehicles never make it to the 15 year mark if they are driven in the winter.
Anyone else watch any of the "just rolled in" or "customer states" youtube videos. Those alone should tell you that safety inspections are a good thing.
I always overlooked non-safty stuff, window tint and loud mufflers aren't gonna kill anyone. And a check engine light is supposed to fail, but I never cared about that.
Your tires need to be ok, brakes good, all suspension components tight, wipers good and actually work, and the lights need to work. No rust holes.
You wouldn't believe the amount of fuel leaks and oil/power steering leaks we would fix. I always would bring the customer out and show them the underneath of their car to explain things. Most trusted us and just said fix what needs to be fixed. I have no problem with that.
We also had a wrecker service, whenever there was a fatal car accident it was impounded at the shop for the state police to investigate the vehicle. That was sobering, as sometimes it was a mechanical failure and the cops followed up on who looked at the vehicle.
I took the safety aspect very seriously.
