Originally Posted By: defektes
Would the rib-cage really be a variable in how well the the oil flows through the filter or would it be the same.
Nothing significant. The media is the real choke point. Try putting some center tubes in an oil bath (or whatever) with and without the medias on them and you will see.
Add that to the inlet and outlet holes, the 180 degree turn the oil has to make, turbulence, pushing the ADBV out of the way, and squeezing the oil between the canister and the threaded end endcap. You can pretty much disregard the cage. Techinically, it is one less obstruction, so the ad writers can put that in as a feature.
