Flatness of the metal-to-metal sealing area is also important on both sides. I'd say the metal end caps are pretty flat, but seems some leaf springs are not, regardless if they ate ruffled or not. We know these stamped leaf springs are too stiff in the sealing area to deflect and close any gap, even when a lot if force is put on the ears. Whip City put so much force on one to see if the gap would close that the ears bent. So if the flatness isn't there even if the surfaces are smooth, there sill could be a gap. Add surface ruffles on top of that, and it could be even worse.
