What's the point of this test?
Most typical family sedans are never used in high stress environments, even if you gave it to the family's teenage son, gave him a full tank, and a case of red bull's.
You are much better off conducting tests using small displacement, high revving, single or twin cylinder engines, of various camshaft configurations, to cover each type of engine design.
V Engines that have multiple OHC setups that are driven by chain drives with multiple cam and valve chains are going to break down the engine oil quicker than the same engine built with an external cam belt.
It might be worth testing an oil to see how much better it deals with the stresses that a chain driven cam-drive setup as compared to it's competition.
BC.
