Noone ever said that. There are just less parts. Those EV motors are cheaper and simpler than the cheapest ICE engine.Wait, nothing ever has to be replaced on EVs. They’re service free. They have zero parts…
Oh wait…
Oh wait…
Lots of people claim that, even on here.Noone ever said that. There are just less parts. Those EV motors are cheaper and simpler than the cheapest ICE engine.
Are you considering each gram of lithium and inch of wiring or something?Lots of people claim that, even on here.
The battery has thousands of parts.
In my car, 384 cells. The packs and cooling are nothing super complex. No I have not assembled a pack, but have seen the teardown, and its not a huge ordeal.There are lots of cells. Then the sense lead and bms wiring IS a big hassle. The balancing boards, the entire cooling system which is on par if not more complex than an ICE. Every weld and connection point is a potential failure point. Then there’s the hv system, contactors, fuses, fets, etc. then the drives, controllers, then the motors. Oh and their cooling loops too in some cases.
Have you ever engineered and built a large battery?? I have. And I’m not trying to be a jerk or pull weight. I just know a little bit of which I speak, not just from YouTube tear downs or websites…. I see the results of safety testing and inadvertent failure. I engage with all the manufacturers. I see stuff not just in the automotive segment.
+1 Truth be told a lot of people seem to think that's the case and some even preach it. All they seem to talk about is how great the batteries are, and how long they last and how little they degrade. They seem to forget about the motor/motors. When called out they'll often say the motors are problem free. LOL Bottom line there's no free lunch!!!!Wait, nothing ever has to be replaced on EVs. They’re service free. They have zero parts…
Oh wait…
That's what Musk said 10 years ago.Wait, nothing ever has to be replaced on EVs. They’re service free. They have zero parts…
Oh wait…
I dunno. I get to drive an 11 second wagon that's perfectly streetable and super cheap to maintain and fuel.+1 Truth be told a lot of people seem to think that's the case and some even preach it. All they seem to talk about is how great the batteries are, and how long they last and how little they degrade. They seem to forget about the motor/motors. When called out they'll often say the motors are problem free. LOL Bottom line there's no free lunch!!!!
Look, I wish you the best. I do.In my car, 384 cells. The packs and cooling are nothing super complex. No I have not assembled a pack, but have seen the teardown, and its not a huge ordeal.
Hard to argue with that!I dunno. I get to drive an 11 second wagon that's perfectly streetable and super cheap to maintain and fuel.
But realize that 384 cells means a LOT more series parallel connections. If laser welded it’s well into the thousands. If torqued, it’s still 700+. Module to module coolant connections are still leak sources as they age. And then liquid cooled power electronics, drives, motors.
It’s just not as simple as being like four monolithic items as some try to make it sound. It’s many, many thousands of failure points that any one can bring the system to a safety critical scenario or worse.
And in that regard they’re really miracles of modern engineering. Enough repeat parts that QC/QA can get reasonable statistical data. Enough knowledge out there to get repeatable manufacturing.
Time will tell how the failure modes go. I certainly wouldn’t buy an EV the way I would a 1980s Mercedes Diesel despite all the moving parts in the drivetrain. Nor would I buy it the same way I would a very old drill or saw, despite both using supposedly tried and true motor technology.
Time will tell about failure modes. We’ve seen some that impact performance or safety.
It's battery cells inside of a few dozen modules set on a coolant plate inside of a case. What you're saying is more like "dude! Your cell phone is so unreliable because of all of the circuit board pathways in it!" I mean, yeah, it has a lot, and I'm sure some fail, but noone with an S24 is stressing over it, and once people get more used to EVs, same same. I mean, people drive manuals with a steel sawblade doing 8k rpm a few inches from their ankles and be eating a burger doing makeup completely unbothered, Lol!Look, I wish you the best. I do.
Exactly. My next option was X3M or Stelvio QV. Both similar performers, both more expensive and much more maintenance intensive. And for what?Hard to argue with that!
Id still like to have my excitement last for longer than eleven seconds.I dunno. I get to drive an 11 second wagon that's perfectly streetable and super cheap to maintain and fuel.
I was just quoting 1/4 mile runs.Id still like to have my excitement last for longer than eleven seconds.
And you don't care about giving up your weekends to fix it- or breaking when it's totally inconvenient.Any vehicle can hit a million miles if you keep on repairing it. I agree the Toyota hybrids are hard to beat for mileage and reliability.
Good point. My guess is there will be issues and there will be improvements, like most products. And some will be better than others.Time will tell how the failure modes go. I certainly wouldn’t buy an EV the way I would a 1980s Mercedes Diesel despite all the moving parts in the drivetrain. Nor would I buy it the same way I would a very old drill or saw, despite both using supposedly tried and true motor technology.
